You may have noticed in the past that sometimes we skip a version in between updates. The most recent example has been right before our last 3.7 release: we went from stable 3.503 to 3.700, skipping 3.600, as we managed to merge a development branch that initially was not planned.
This has created some confusion while communicating with our community in between 3.500 and 3.700 since we often referred to our internal build as 3.600. From now on then, we’ll pick a wholesome vegetable or fruit as a codename for the next scheduled release in development.
The codename for our next 3DF Zephyr release (planned for the end of May 2018) is Avocado.
Will Avocado be 3DF Zephyr 3.800 ? 4.0? We’re not sure yet. That’s why we’re moving to vegetables since 1 Avocado will always amount to 1 Avocado, and that’s solid math right there.
Lets quickly have a look at what’s cooking in our development kitchen office.
· Making Samantha faster than ever
Accuracy matters, and that will always be our top priority. If you’ve followed the 3DF Zephyr development during the years, you may have noticed that often in our changelog we’ve had improved the speed of Samantha – our leading, state of the art, structure from motion technology – and overtime, those little 5%-10% speed increments have added up to quite a bit. With Avocado however, Samantha has shown speed improvements that range from 20% to a whopping 80% – all of this without losing accuracy.
Here is an example on a building reconstructed with 293 photos:
One counterintuitive aspect of this improvement is that the higher the image resolution and the number of images, the more relevant the speed improvement!
· Merging the development branch of the new improved Stasia
The new improved Stasia is capable of extracting much more details than ever! So while the computation is more or less the same than the current 3.702 release, the results are very promising from our initial testing. Lets see this example: the following mesh have been generate at default settings (same 293 images as above) from two different clouds, on the left from 3.702 and on the right from Avocado – both with the same running time of roughly 45 minutes. Please note that this is the raw surface without any photo-consistent optimization.
With the new improvements will be generally able to recover more fine details and thin structures. It’s important to notice that the final amount of points is more or less the same. As you probably know, the density of the points doesn’t influence accuracy. A better initial solution for the photoconsistency will certainly lead to a better final result. Furthermore, we are planning to decrease the overall running times before the new release.
· Sharper photoconsistency filter
We are testing our photoconsistency filter to be able to extract more details on very sharp / planar features. Combined with the new Stasia, sharp meshes will look even better than they do now. We don’t have much to show yet, but it’s good to let you know there are improvements coming 🙂
· Spring code cleaning
Merging new code that has been developed for a while on a separate branch is always good motivation for some code cleanup. This has been a great chance for us to get rid of some old legacy code that was making development of certain parts slower than it should have been. We strive to deliver updates every few months and periodically cleaning our code is required to keep our development process agile as well as robust.
With this internal codebase maintenance we’re also taking the opportunity to rewrite the code needed to (finally!) bring our SDK to Linux. Although there are no plans to bring the full 3DF Zephyr application to Linux ( 🙁 ) porting our core technology to it is a needed step that will benefit all of our current and future SDK customers.
· Even more tools for workflow management
Although it is already possible to manually handle custom camera calibrations and presets, for those who need these feature frequently there is currently a lot of repetitive work when starting a new project, with the task of organizing your calibrations/presets file left to the user.
· Even more selection tools
![]() | We’re not aiming to replace Blender or other similar software suites – we’re focused on 3D modeling from reality, but we’ve always valued the possibility to do some minor cleaning / editing directly within Zephyr – as minor as those edits are, they can really save a lot of time. With Avocado, we’ve doubled the selection tools available by adding to our existing square selection and polygon selection tools an ellipse selection tool and a lasso selection tool. That’s the kind of useful feedback we constantly get from our Facebook 3Dflow Academy group and Forum. Being able to deploy new features you ask and see you trying them in just a few weeks is always great for us: thank you for your continued feedback 🙂 |
· Orthophoto generation from dense point clouds
It is currently required to generate a mesh in order to obtain an orthophoto – otherwise, you have to rely on a controlled mosaic generation. With the upcoming Avocado release however, the orthophoto generation can be computed on any dense point cloud, including unstructured point clouds. While it’s always better to generate the orthophoto from the mesh, sometimes it’s useful to generate it quickly from a dense point cloud, especially from colored point cloud coming from laser scans.
· Much more!
There are also many more minor features we’re working on: although those listed here will probably be the highlights of the Avocado release, depending on the development progress we may or may not merge other development branches of other features. Until the next development update post, you can refer to this Avocado wiki page on 3dscanninghacks.com
Feedback or ideas you’d like to share? Let us know on our Facebook 3Dflow Academy group or on our Forum!
