3DF Zephyr license activation error codes
Please refer to this list in order to troubleshoot 3DF Zephyr licenses activation error codes.
Code | Problem | Solution |
1 | generic error | Please contact support at support@3dflow.net |
30 | Network Bad Reply | Network error. Bad reply from server. Please try again later. If the problem persists, please contact support at support@3dflow.net |
31 | Network Timeout | Network error. Timeout reached. Please check your internet connection or try again later. |
32 | Network Proxy Issue | Proxy configuration problem. Please check your internet connection, contact your system administrator or try again later. |
33 | Network SSL Issue | SSL configuration problem. Please check your internet connection, make sure that youre date/time/timezone is set correctly and that your computer is up to date, or try again later. Contact your system administrator if the problem persists. |
34 | Network Issue | Please check your internet connection or try again later. |
41 | Invalid Lease Drop | Invalid lease drop request. The current lease is invalid and can’t be dropped from the server. |
42 | Invalid key | The key cannot be validated from the server. Please contact support at support@3dflow.net |
43 | Invalid key | The key cannot be validated from the server. Please contact support at support@3dflow.net |
44 | Invalid key | The product key has an invalid format. Please double-check the entered product key. |
45 | Invalid Date/Time | Your computer has the wrong time/date/timezone. Try to fix the date/timezone on your pc (set automatically). |
46 | Invalid fingerprint | Unable to read the machine fingerprint. Please contact support at support@3dflow.net |
47 | Expired Lease | Lease expired. Your product key has expired. Try restarting 3DF Zephyr and/or check your internet connection. |
48 | Lease Limit Reached | Max concurrent activation limit reached. Please make sure to exit running processes from other machines before using the product on the current one. |
49 | Lease Unavailable | Cannot acquire lease from server. The hardware fingerprint might be different. Please try deactivating and reactivating the product. |
Other codes | Internal error | Please contact support at support@3dflow.net with the relevant details (license key, error code, machine information). |
If you are looking for the legacy error codes (all versions before 7.0) please check https://www.3dflow.net/3df-zephyr-license-activation-error-codes-legacy/
