iPhone X True Depth Camera Support
  • vbongioanni
    • Dec 2017
    Use distance data from the iPhone X True Depth camera to improve the accuracy of 3D models.
    • 1366
    Hi vbongioanni,
    thank you for your suggestion, however depth cameras are not enough accurate to improve structure from motion accuracy. When the tech becomes more accurate, then an integration may make sense, but not at this stage
    • Scott Nebeker
      • Sep 2016
      • 28
      Bingo on Andrea' point. The tech is too new to fully implement like this. It would force the dev team into a constant cat and mouse game as they try to keep up with a maturing tech.
      That said. It might be worth taking a shot with one lens then switching to the other for a second shot. You've got two lenses, so you've basically got two cameras, one narrow, one wide. I feel like this must be SCIENCED!
      There's little things to be worked out but dual lens devices will definitely prove useful in the future.
      Good suggestion, BTW.
