Retain active Workspace Tool function when Panning/Orbiting
  • sam3d
    • 98
    Currently the active tool is cancelled if the viewport changes by orbiting/zooming.
    Could this be changed so the tool stays active? This would be helpful when trying to accurately define a plane or measuring etc
    This seems more like a bug than a feature
    The selection tools (like the plane selection tool) remain active while panning/orbiting. What tool doesn't work? Can you make a quick video or share some screenshots?
    Thanks!
    • sam3d
      • 98
      Hi Roberto
      I've made a quick screen recording showing the issue while the Measure tool but it's the same with the Plane Vector tool. Zooming is actually okay on it's own but panning stops the active tool.
      I'd find it useful to be able to orbit/pan/zoom while the workspace tools are active for selection accuracy. For example I'd like to be able to level a mesh from a known feature (a building's damp proof course/plinth etc) picked from opposing elevations using the Plane Vectors tool.
        • 1366
        Hi Sam,
        I confirm it's a bug, thank you for reporting it! We'll fix it in the next release.
        In the meantime, as a workaround, use the WASD navigation rather than the orbit/orbit pivot navigation to obtain the desired behaviour.
          • 1366
          Filippo fixed it in the current beta build thanks again for reporting!
          • sam3d
            • 98
            Speedy!
            I tried the WASD keys but the camera didn't move; any ideas why? The keypad functions work though - zoom, up, down etc
              • 1366
              you probably didn't select the WASD mode (you need to switch from the toolbar)
              • sam3d
                • 98
                Got it, thanks!
