Info about skipped photos during reconstruction process
  • josua
    • May 2020
    • 24
    During the initial import of photos, Zephyr tries to orient the photos, and some of them sometimes fail. It would be really good for the user if there was a possibility to click on the Photos with the Status Reconstructed=NO and get some additional info about the reason WHY Zephyr failed to orient this photo. Maybe there could also be a hint to "try Setting xyz". So it is all about educating and guiding the user.
    • 1346
    Hi Josua,
    unfortunately this is heavily context-dependent, so I doubt this will ever be a feature. However, note that while it will be unlikely zephyr will tell you to try a specific change, you can get a hint by checking the logs and looking exactly what happened, e.g. low number of keypoints / matches, cluster merge rejected, and so on
    • josua
      • May 2020
      • 24
      Ok, thanks for the info, I will check the logs next time! I want to be learn from the logs
