Zephyr photo limits
  • plainsight
    • Dec 2020
    Zephyr photo limits
    I've used the free version with the 50 photo limits and decided to purchase the lite edition which is up to 500.
    When I tried the video import. The issue I have is when you run the workflow and certain photos are not usable for reconstruction, which cuts into the limits.
    example:
    Say my video has 600 frames, but the limit is 500. So I have to get rid of 100 frames.
    Okay run reconstruction only 400 frames are usable. So what of the 100 frames I could have checked?
    My suggestion is
    1. the limits should only be usable photos.
    2. or a tool to quickly remove the unusable frames from directory before beginning the workflow process
  • Macktek
    • Jan 2021
    Great Idea!. I had this same issue myself.
      • 1366
      You can already remove the N/A photos (right click, "select all not oriented", right click, "remove") and then add the remained of the photos normally via workflow -> add photos
