Custom Settings Report
  • RPTx_RS
    • May 2024
    Hi, it would be nice to be able to see the particular settings used after every phase of the process. The quality report available gives alot of information on the cameras but, i cannot see specifically what settings i used as i search for the best results. i am having to write down the settings i apply at the front end with the wizard, to know what i had.
    • 689
    HiRPTx_RS - Right click on the sparse/dense/mesh etc... in the project panel, you can open the properties to see which settings were used. You can also export these settings to a text file for convenience.
    • RPTx_RS
      • May 2024
      Thank You cam3d !!! that is excatly what i was looking for.
