Slight Problem When Changing Brush Size in Masquerade
  • Paul King
    • Nov 2017
    • 10
    Hi All,
    Has anyone had a slight problem when changing a brush size in masquerade? Sometimes the program stops working but to be honest, it is is only a small glitch as nothing is lost work-wise
    Paul
    Ciao Paul,
    welcome to the forums !
    Can you describe step-by-step how to reproduce the issue? thank you
    • Paul King
      • Nov 2017
      • 10
      Ciao Paul,
      Ciao Andrea,
      Thank you for the warm welcome.
      When reducing the brush size after using the default setting whilst masking a small window pops up saying "Masquerade has stopped working" or something similar to that.
      So, using the default brush for large areas, I then dragged the slider to the left to create a smaller brush, this is when the program stops but it doesn't happen all the time.
      As I say, it has only happened a few times and nothing serious happened.
      If it does happen again I will try and note exactly what I was doing at the time
      Ciao for now
      Paul
        I tried playing randomly with the brush size but i couldn't reproduce it
        Even if it is something that happens seldom we'd like to fix it anyways so yes, please let me know how to reproduce it if you find a way!
        Cheers!
          Hi Paul,
          we were able to reproduce and fix the crash in the last release (v. 3.503). Thanks for reporting it
