Version 3.5
    Version 3.5
    3.500 Changelog:
    3.501 Changelog:
    • Fixed a bug in Structure from motion causing crashes and random behavior in some cases.
    • Fixed a crash occurring when renaming a mesh and creating a new one.
    • Fixed some Unicode exporting problems.
    • Fixed problems with video decoding of some formats.
    • Fixed an issue causing crash during mesh extraction in some rare cases.
    • Fixed a problem with psz import
    • Added activation return codes
    • Corrected a picking problem with some sparse point cloud.
    • Added ctrl + d shortcut to clear selection while using selection tools.
    • Removed some silly initialization warnings
    • Can now structure and unstructure a mesh also in the lite version (useful for importing back a mesh to texture it again)
    • Fixed a problem during workspace merge with processor without SSE 4.2 instructions
    • Minor ui fixes
      3.502 Changelog
      • Added benchmarking tool
      • Added viewfinder widget in Control point / polyline tools (Pro/Aerial only)
      • Fixed a crash when adding images.
      • Fixed a problem in SfM pipeline (was discarding good images under certain condition).
      • When loading an autosave, you are now forced to "save as" on first save.
      • Fixed a crash in the Image quality index
      • Fixed a crash in ICP report dialog when threshold is set to avery low number.
      • Fixed a bug in the progress bar / system window remaining unrensposive.
      • Improved the default shader.
      • Minor fixes.
