Cuda
  • 55thSwiss
    • Jan 2018
    Cuda
    I've done everything I can to try and force Zephyr to use my GPU. I've installed the latest drivers for my card and configured the card specifically for Zephyr to run with the card's processor. Still, Zephyr will not recognize it. Below are the specs for my card. Any suggestions?
    NVIDIA System Information report created on: 01/08/2018 18:16:00
    System name: F360_LAPTOP
    [Display]
    Operating System: Windows 7 Professional, 64-bit (Service Pack 1)
    DirectX version: 11.0
    GPU processor: Quadro K1000M
    Driver version: 312.69
    DirectX support: 11.1
    CUDA Cores: 192
    Core clock: 850 MHz
    Memory data rate: 1800 MHz
    Memory interface: 128-bit
    Memory bandwidth: 28.80 GB/s
    Total available graphics memory: 9767 MB
    Dedicated video memory: 2048 MB DDR3
    System video memory: 0 MB
    Shared system memory: 7719 MB
    Video BIOS version: 80.07.33.00.0F
    IRQ: 0
    Bus: PCI Express x16 Gen2
    [Components]
    easyDaemonAPIU64.DLL 1.11.3.0 NVIDIA Update Components
    WLMerger.exe 1.11.3.0 NVIDIA Update Components
    daemonu.exe 1.11.3.0 NVIDIA Update Components
    ComUpdatus.exe 1.11.3.0 NVIDIA Update Components
    NvUpdtr.dll 1.11.3.0 NVIDIA Update Components
    NvUpdt.dll 1.11.3.0 NVIDIA Update Components
    nvui.dll 8.17.13.1269 NVIDIA User Experience Driver Component
    nvxdsync.exe 8.17.13.1269 NVIDIA User Experience Driver Component
    nvxdplcy.dll 8.17.13.1269 NVIDIA User Experience Driver Component
    nvxdbat.dll 8.17.13.1269 NVIDIA User Experience Driver Component
    nvxdapix.dll 8.17.13.1269 NVIDIA User Experience Driver Component
    NVCPL.DLL 8.17.13.1269 NVIDIA User Experience Driver Component
    nvCplUIR.dll 8.1.970.0 NVIDIA Control Panel
    nvCplUI.exe 8.1.970.0 NVIDIA Control Panel
    nvWSSR.dll 6.14.13.1269 NVIDIA Workstation Server
    nvWSS.dll 6.14.13.1269 NVIDIA Workstation Server
    nvViTvSR.dll 6.14.13.1269 NVIDIA Video Server
    nvViTvS.dll 6.14.13.1269 NVIDIA Video Server
    NVSTVIEW.EXE 7.17.13.1269 NVIDIA 3D Vision Photo Viewer
    NVSTTEST.EXE 7.17.13.1269 NVIDIA 3D Vision Test Application
    NVSTRES.DLL 7.17.13.1269 NVIDIA 3D Vision Module
    nvDispSR.dll 6.14.13.1269 NVIDIA Display Server
    NVMCTRAY.DLL 8.17.13.1269 NVIDIA Media Center Library
    nvDispS.dll 6.14.13.1269 NVIDIA Display Server
    NVCUDA.DLL 8.17.13.1269 NVIDIA CUDA 5.0.1 driver
    nvGameSR.dll 6.14.13.1269 NVIDIA 3D Settings Server
    nvGameS.dll 6.14.13.1269 NVIDIA 3D Settings Server
    Hi 55thSwiss,
    does zephyr shows on startup a popup? If so, can you please past or screenshot what the message says?
    If not, simply make sure the card is actually enabled in the Tools -> Options -> Cuda tab.
    Hope this helps!
    • 55thSwiss
      • Jan 2018
      The first time I started Zephyr I did get a pop up notifying me it did not see and Cuda cores. Since then, the only pop up on starting is a facebook like thing or to purchase pro (running free version obviusly). Attached is the screen shot of my options menu, it's not even recognizing the card?
        It's odd that it's not recognizing it if you're using the latest available drivers.
        Please double check that CUDA is installed on your system. It should have come with the latest drivers but if for some reason it's not installed on your system, you can install it as a standalone package with the toolkit.
        (you don't need sources and samples, so you can stick with a basic installation).
        Hope this helps
        • 55thSwiss
          • Jan 2018
          Ok, thanks Andrea. I downloaded the network installer for windows 7, 64 bit but I'm getting a lot of bugs on the step for building the nbody for Visual Studio. I'm guessing it's because I have VS 2017 Community edition? The versions of VS it lists as compatible does not explicitly say Community edition?
            I haven't installed the network package in a while, i usually download the full ~1.3GB package instead since i usually deploy it on more than one machine. It should install fine though. Maybe try the non-network as well?
            Is it by chance a virtual machine?
            • 55thSwiss
              • Jan 2018
              No, not a virtual machine. Let me try to full install though like you said. No idea about is VS 2017 Community is supported though?
                it shouldn't be an issue, as you don't need the development stuff it brings with it
