3DF Zephyr road to 3.6 (or 3.7?)
  • 3Dflow
    Administrator
    • Jun 2017
    • 18
    Feel free to use this topic to discuss the upcoming features and beta build
    v.3.561 changelog
    • Added support to multi-texture generation
    • Added Radiometric calibration (soon: support to multi-spectral images )
    • Added "shutdown computer" function
    • Added .fbx import support
    • Added keyboard shorcuts to 3DF Masquerade
    • Added position constraint in bundle adjustment for RTK GPS
    • Added layers management in cameras
    • Fixed an issue when defining the up vector Y to workspaces created with Z as up vector
    • Fixed an issue when selecting cameras in import mesh with UV
    • Minor bugfixes
    • Minor UI changes
    • Minor 3DF Masquerade fixes
    • Nedo
      3Dflow Cup 2018 winner
      • Nov 2016
      • 71
      Hi Roberto, i would like to test the beta, so i need a beta key right?
        I'm sending you the key and the link by email
          v.3.562 changelog
          • Fixed a bug with Sketchfab uploader
          • Images are automatically grouped into different layers
          • Fixed a problem with importing a mesh with external uv map
          • Texturing improvements
          • Fixed a problem with multigpu during MRF computation (it was actually using only 1 gpu)
          • Added an hidden 'ProfessionalLayout' command in the console
          • Nedo
            • Nov 2016
            • 71
            Hi Roberto can i ask questions about the beta here?
            Yesterday i tested the latest beta the sleep function, i started a dense cloud calculation on ultra and set the timer from 00:00 to 06:00
            Today i woke up and saw the computer was shut down but when i reloaded the project it didnt have any dense point cloud,
            is there a log file what happened? maybe it crashed hmmm
            greets Nedo
              Hi Nedo,
              you can find all the logs here:
              The 3DF Zephyr log files are just a few clicks away. Learn how to find logs for all 3DF Zephyr versions.
              If you can send me the last log it would be very helpful. I suspect Zephyr didn't save the project before shutting down :\. It hasn't be fully tested so it might be still buggy. If it was a crash Zephyr wouldn't have been able to shut down the computer . Thanks for reporting this
                Ok no need to send us the log, I think we have found and fixed the problem. Now it should save the current workspace properly in the desktop before closing . Rolling out a new beta:
                v.3.563 changelog
                • Fixed a problem with automatic shutdown and workspace saving
                • Fixed a crash in the preset selection page
                  v.3.564 changelog
                  • Fixed a problem with georeference data and polyline tools
                  • Fixed a minor issue with texturing
                  • Added custom color map to the dem viewer
                  • Added 'remove masks' command
                  • Fixed a problem with camera calibration and Zephyr in italian languages (cameras not showing up)
                  • Fixed a problem with layer creation in the add photos page of the main project wizard
                  • Activation and licenses are now 'per machine' rather than 'per user'
                  • Nedo
                    • Nov 2016
                    • 71
                    Just an info, zephyr 3.564, yesterday i started a new project (dense cloud) with the sleep modus, i setup 00:00 to 06:00
                    At 7:30 i woke up and saw the computer is still running, no shut down instead a message where it says it could not save
                    the project, i found out why, the SSD was full ! I saved it manually then without a problem.
                    This time i'm happy it didnt shut down
                      "Working as expected" thanks for the feedback
                        v.3.565 changelog
                        • Added multispectral support for orthophoto generation with multispetral transform composition
                        • Added multispectral viewer with colormaps support
                        • Fixed a problem with sparse point cloud and selection (points were disappearing)
                        • Added support for 3fr raw cameras (hasselblad)
                        • Utility menu reorganized
                        • Minor fixes
                        • herrkjeldsen
                          • Oct 2017
                          I am getting "Failed to import file" when importing Mesh with known uv-map. Seems to load correctly in the steam version though. Otherwise I have encountered no issues what so ever so far
                            Hi herrkjeldsen!
                            can you please send us the mesh you're having issues with? This way we can reproduce and kill the bug
                            thanks for the feedback!
