3DF Zephyr road to 3.6 (or 3.7?)
  • 3Dflow
    Administrator
    • Jun 2017
    • 18
    Feel free to use this topic to discuss the upcoming features and beta build
    v.3.561 changelog
    • Added support to multi-texture generation
    • Added Radiometric calibration (soon: support to multi-spectral images )
    • Added "shutdown computer" function
    • Added .fbx import support
    • Added keyboard shorcuts to 3DF Masquerade
    • Added position constraint in bundle adjustment for RTK GPS
    • Added layers management in cameras
    • Fixed an issue when defining the up vector Y to workspaces created with Z as up vector
    • Fixed an issue when selecting cameras in import mesh with UV
    • Minor bugfixes
    • Minor UI changes
    • Minor 3DF Masquerade fixes
    • Nedo
      3Dflow Cup 2018 winner
      • 71
      Hi Roberto, i would like to test the beta, so i need a beta key right?
        I'm sending you the key and the link by email
          v.3.562 changelog
          • Fixed a bug with Sketchfab uploader
          • Images are automatically grouped into different layers
          • Fixed a problem with importing a mesh with external uv map
          • Texturing improvements
          • Fixed a problem with multigpu during MRF computation (it was actually using only 1 gpu)
          • Added an hidden 'ProfessionalLayout' command in the console
          • Nedo
            • 71
            Hi Roberto can i ask questions about the beta here?
            Yesterday i tested the latest beta the sleep function, i started a dense cloud calculation on ultra and set the timer from 00:00 to 06:00
            Today i woke up and saw the computer was shut down but when i reloaded the project it didnt have any dense point cloud,
            is there a log file what happened? maybe it crashed hmmm
            greets Nedo
              Hi Nedo,
              you can find all the logs here:
              The 3DF Zephyr log files are just a few clicks away. Learn how to find logs for all 3DF Zephyr versions.
              If you can send me the last log it would be very helpful. I suspect Zephyr didn't save the project before shutting down :\. It hasn't be fully tested so it might be still buggy. If it was a crash Zephyr wouldn't have been able to shut down the computer . Thanks for reporting this
                Ok no need to send us the log, I think we have found and fixed the problem. Now it should save the current workspace properly in the desktop before closing . Rolling out a new beta:
                v.3.563 changelog
                • Fixed a problem with automatic shutdown and workspace saving
                • Fixed a crash in the preset selection page
                  v.3.564 changelog
                  • Fixed a problem with georeference data and polyline tools
                  • Fixed a minor issue with texturing
                  • Added custom color map to the dem viewer
                  • Added 'remove masks' command
                  • Fixed a problem with camera calibration and Zephyr in italian languages (cameras not showing up)
                  • Fixed a problem with layer creation in the add photos page of the main project wizard
                  • Activation and licenses are now 'per machine' rather than 'per user'
                  • Nedo
                    • 71
                    Just an info, zephyr 3.564, yesterday i started a new project (dense cloud) with the sleep modus, i setup 00:00 to 06:00
                    At 7:30 i woke up and saw the computer is still running, no shut down instead a message where it says it could not save
                    the project, i found out why, the SSD was full ! I saved it manually then without a problem.
                    This time i'm happy it didnt shut down
                      "Working as expected" thanks for the feedback
                        v.3.565 changelog
                        • Added multispectral support for orthophoto generation with multispetral transform composition
                        • Added multispectral viewer with colormaps support
                        • Fixed a problem with sparse point cloud and selection (points were disappearing)
                        • Added support for 3fr raw cameras (hasselblad)
                        • Utility menu reorganized
                        • Minor fixes
                        • herrkjeldsen
                          • Oct 2017
                          I am getting "Failed to import file" when importing Mesh with known uv-map. Seems to load correctly in the steam version though. Otherwise I have encountered no issues what so ever so far
                            • 1365
                            Hi herrkjeldsen!
                            can you please send us the mesh you're having issues with? This way we can reproduce and kill the bug
                            thanks for the feedback!
