OBJ Export with filled holes
  • wolfp
    i've tried your software and it works realy good. Only if i try to fill holes in the model ( with "watertight") I can't export the result as obj. In the viewport it looks fine but it exports the
    model without filled holes.
    • 1366
    Hi wolfp!
    Glad to hear you like Zephyr
    Make sure you're exporting the correct mesh - the most common error is to get to the textured mesh, click "fill holes" and not realize zephyr selected for you the first mesh (not mesh with texture) even in the workspace. If this is the case, simply re-generate a mesh with texture with the new mesh (with holes filled) as input to the mesh with texture generation.
