Best image format?
  • Wegg
    • Mar 2018
    Best image format?
    Are there any advantages to the higher bit depth image formats that are supported? Is an .ARW image going to produce better results than a high quality .jpg or .png?
    • 1366
    Hi Wegg,
    unless you require that type of texture (usually known in vfx) you can safely use jpgs or png (they are also faster to load). However, if you shoot in raw you'll have the ability to do small adjustment (brightness, contrast..) before exporting them to jpg, if needed
