Erasing Floating Elements
  • 3dscanreality
    • May 2017
    • 25
    Hi there,
    first of all, sorry for being a pain in the as* lol but i'm wondering if there is any option to erase small floating elements around the object at the mesh phase.
    i mean, like gradual selection on photoscan where it keeps the main mesh but any other point or aglomerate of small points are erased if not conected to the mesh
    Many thanks
    • 1365
    Hi!
    no need to apologize, all questions are always welcome
    You can use triangle selection, i suggest the lasso (2).
    https://www.3dflow.net/wp-content/uploads/2016/05/pointcloud_cleaning.jpg
    Connect it to select the region you do not want and then delete it (5)
    It's worth pointing out that these tools (1,2,3,4,5) works both for point cloud and meshes.
    You can find more explanations here https://www.3dflow.net/technology/documents/3df-zephyr-tutorials/tutorial-cleaning-point-clouds/ (i found especially useful the select by color tool for point clouds, for example when you have sky bleeding in dense point clouds) but feel free to ask any other question!
    • 3dscanreality
      • May 2017
      • 25
      thank you
        • 559
        Actually the small connected components automatic removal filter as you meant is not available. You have to do it manually as Andrea suggested. However, we have also that filter in our todo-list and hopefully it will appear in the next updates.
        • 3dscanreality
          • May 2017
          • 25
          great!! I'm really into this software... I understand that there's a few things to improve like this one but in the other hand, I love the sturdiness of this thing
          congrats
            • 559
            I confirm this filter will be added in the next update (probably next week) :3
            • pconnell
              • Jul 2016
              This would be very useful, seems the biggest part of the workflow is trimming out bits you don't want from a scan. Looking forward to it (if it is in Lite of course, otherwise )
                • 1365
                yes, It will be in the lite as well
                There are actually some other filters coming. My favourite new one is the selective smoothing/retopology. Basically you will be able to select certain triangles and apply smoothing/retop only on those triangles. Very useful to retop/smooth out only certain areas, for example flat surfaces !
                  • 1365
                  Made a quick video of the aforementioned tool. I REALLY like this new feature
