Best way to handle this in 3D FLOW?
  • CG-Guy
    • Apr 2018
    • 151
    I generated various stages of a pizza from raw to cooked to cooked with missing pieces, individual pieces and then the crust parts - I have 4 pieces of crust that I constructed at the same time as one mesh
    I'm trying to make the mesh water tight on these 4 meshes that are currently treated as one object. The fill water tight is attempting to patch them all together. The question is can I bust them into separate objects in the file and then do a water tight on each of the 4 parts then run retopology on them?
    thanks for any advice
    • 1366
    Hi CG-Guy,
    if I understand correctly your scene has four pieces, that are disconnected and you'd like to run the fill filter on each separate mesh.
    You can easily do so in the mesh phase: simply select the first crust piece using the polygon tool and then create a new object via cut, and repeat it for the other objects. Now you'll have four separate mesh in your workspace. Simply run the filter you'd like on each one of them, and then create the textured mesh for each one of your mesh.
    • CG-Guy
      • Apr 2018
      • 151
      That worked out great - thanks for the quick help
