How do I export with the Full level of Detail for textures
  • Gregchop
    • 38
    #15
    This is the best mesh I have been able to produce, sorry for the confusion, I did figure out the export texture....was focusing on the MESH now
      • 1364
      #16
      Oh, so you're problem is not tied to the texture then? Ok, i'll try to process your photos tomorrow.
      On a side note, avoid removing exif data and try taking better pictures. I don't know what ISO speed you used since you stripped the exif data but there is a lot of room for improvements, as there is a lot of noise due to a very high ISO speed.
      • Gregchop
        • 38
        #17
        What ISO Speed you recomend ? I used 1000. When you avoiding removing exif data, not sure what you mean, I did no post processing..the images I sent you were the RAW (NEF)
        images right ? Exactly how did you detect a high amount of noise ?
          • 1364
          #18
          Here are some general shooting tips https://www.youtube.com/watch?v=E06k...ature=youtu.be
          I personally shoot at ISO-100 or ISO-200. I don't see exif data on the file you sent me, but that's no issue for this specific topic:
          Simply look at your images at their 1:1 zoom or the texture generated by Zephyr.
          Click image for larger version  Name:	gregnoise.jpg Views:	1 Size:	535.7 KB ID:	2282
          that's ISO speed noise on your images. Which means either you're stuck using a lower resolution inside zephyr (See Roberto's post) or taking better images.
          • Gregchop
            • 38
            #19
            OK ISO 200 it is...will rescan accordingly
            • Gregchop
              • 38
              #20
              So...here are scans one from the ISO 1000 and one from the ISO100, to my eyes I really don't see much difference, processing them now through 3Dflow
              • Gregchop
                • 38
                #21
                Please update the images I sent you with the new ones, as the new ones are the ones Agisoft will be using as well
                  • 1364
                  #22
                  What is your target vertex count by the way? here is a simple result using presets (close range/default, close range/high details, close range/high details sharp features + additional PC, defaults 8k).
                  It is fairly low poly but looking at your screenshot you were aiming for something smaller? this one is 178k points (305k triangles). Let me know if you have a target vertex count so i can decimate it to your target as well for better comparison.
                  Click image for larger version  Name:	gregmesh.jpg Views:	1 Size:	57.8 KB ID:	2294
                  As for the texture, the new photos are better, as you can see with lower iso you get much less noise
                  Click image for larger version  Name:	gregtexdetail.jpg Views:	1 Size:	76.0 KB ID:	2295
                  Click image for larger version  Name:	gregA.jpg Views:	1 Size:	68.6 KB ID:	2296
