Free version: Failed to allocate memory
  • SarahC
    • Mar 2018
    • 30
    I'm getting the following error making the textured mesh from a high detail point cloud - produced by a Canon 7D mark II with an 18mm lens, at f/11. 26 images.
    My GTX 970 GPU meter shows my free card memory is at 3.5GB, using only 500MB. (14%) It's running cold.
    My RAM usage is 18GB with 14GB free.
    I've included the models (800MB, 1.2GB unzipped, 20 mins download):
    "Textured mesh 3" is the one where the problem occurred - the detail is exquisite, even though there was some wind moving the leaves.
    The failed texture loading can be seen in the bushes at the right of the bins, and on the front of the green bin.
    [04:04:12] Error in computing Undistorted image: [instance(0,0,0,0,0000000000000000,non-shared)] CImg<float>::CImg(): Failed to allocate memory (34.8 Mio) for image (2500,3648,1,1).
    [04:04:12] Unable to load '_89a8812.jpg' file!
    [04:04:13] Unable to load '_89a8834.jpg' file!
    [04:04:13] Error in computing Undistorted image: [instance(0,0,0,0,0000000000000000,non-shared)] CImg<float>::CImg(): Failed to allocate memory (15.9 Mio) for image (2500,1667,1,1).
    [04:04:13] Unable to load '_89a8815.jpg' file!
    [04:04:13] Preparing image : '_89a8816.jpg'
    [04:04:14] Unable to load '_89a8816.jpg' file!
    [04:04:14] Preparing image : '_89a8820.jpg'
    [04:04:16] +++ ERROR +++ (computation error)
    [04:04:17] +++ ERROR +++ (computation error)
    [04:04:17] Done.
    [04:04:21] Computing blurriness...
    [04:05:31] Done.
    [04:05:31] Applying photoconsistency score...
    [04:05:31] Done.
    [04:05:32] Building connectivity...
    [04:05:35] Done.
    My detailed system configuration:
    Summary
    Operating System
    Windows 10 Pro 64-bit
    CPURAM
    32.0GB Dual-Channel DDR3 @ 665MHz (9-9-9-24)
    Motherboard
    Dell Inc. 0HY9JP (CPU 1)
    GraphicsStorageOptical Drives
    HL-DT-ST DVD+-RW GH70N
    ELBY CLONEDRIVE SCSI CdRom Device
    Audio
    High Definition Audio Device
    Operating System
    Computer type: Tablet
    Installation Date: 1/2/18 03:40:00
    Serial Number: TY4CG............
    Windows Security Center
    User Account Control (UAC) Enabled
    Notify level 2 - Default
    Firewall Enabled
    Windows Update
    AutoUpdate Not configured
    Windows Defender
    Windows Defender Enabled
    Antivirus
    Windows Defender
    Antivirus Enabled
    Virus Signature Database Up to date
    Sophos Anti-Virus
    Antivirus Disabled
    .NET Frameworks installed
    v4.7 Full
    v4.7 Client
    v3.5 SP1
    v3.0 SP2
    v2.0 SP2
    Internet Explorer
    Version 11.248.16299.0
    PowerShell
    Version 5.1.16299.15
    Java
    Java Runtime Environment
    Path C:\Program Files (x86)\Java\jre1.8.0_161\bin\java.exe
    Version 8.0
    Update 161
    Build 12
    Environment Variables
    USERPROFILE C:\Users\sarah
    SystemRoot C:\WINDOWS
    User Variables
    OneDrive F:\sarah\OneDrive
    Path C:\Users\sarah\AppData\Roaming\npm
    C:\Users\sarah\AppData\Local\Microsoft\WindowsApps
    TEMP C:\Users\sarah\AppData\Local\Temp
    TMP C:\Users\sarah\AppData\Local\Temp
    Machine Variables
    ADSK_3DSMAX_x64_2017 D:\Program Files\Autodesk\3ds Max 2017\
    ADSK_CLM_WPAD_PROXY_CHECK FALSE
    ComSpec C:\WINDOWS\system32\cmd.exe
    NUMBER_OF_PROCESSORS 8
    OS Windows_NT
    Path C:\ProgramData\Oracle\Java\javapath
    C:\Windows\system32
    C:\Windows
    C:\Windows\System32\Wbem
    C:\Windows\System32\WindowsPowerShell\v1.0\
    D:\Program Files\Terminals\Putty\
    D:\Program Files\Terminals\WinSCP\
    D:\Program Files\SrcCtl\Git\cmd
    C:\Program Files\nodejs\
    C:\Program Files (x86)\Common Files\Acronis\VirtualFile\
    C:\Program Files (x86)\Common Files\Acronis\VirtualFile64\
    C:\Program Files (x86)\Common Files\Acronis\SnapAPI\
    C:\WINDOWS\system32
    C:\WINDOWS
    C:\WINDOWS\System32\Wbem
    C:\WINDOWS\System32\WindowsPowerShell\v1.0\
    C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common
    C:\Program Files (x86)\QuickTime\QTSystem\
    C:\Program Files\Common Files\Autodesk Shared\
    C:\Program Files (x86)\Autodesk\Backburner\
    C:\WINDOWS\system32
    C:\WINDOWS
    C:\Program Files (x86)\Calibre2\
    PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;. MSC
    PROCESSOR_ARCHITECTURE AMD64
    PROCESSOR_IDENTIFIER Intel64 Family 6 Model 42 Stepping 7, GenuineIntel
    PROCESSOR_LEVEL 6
    PROCESSOR_REVISION 2a07
    PSModulePath %ProgramFiles%\WindowsPowerShell\Modules
    C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules
    C:\Program Files\Intel\Wired Networking\
    TEMP C:\WINDOWS\TEMP
    TMP C:\WINDOWS\TEMP
    USERNAME SYSTEM
    windir C:\WINDOWS
    Power Profile
    Active power scheme High performance
    Hibernation Enabled
    Turn Off Monitor after: (On AC Power) Never
    Turn Off Hard Disk after: (On AC Power) Never
    Suspend after: (On AC Power) Never
    Screen saver Enabled
    Uptime
    Current Session
    Current Time 23/4/18 04:12:19
    Current Uptime 3,011,830 sec (34 d, 20 h, 37 m, 10 s)
    Last Boot Time 19/3/18 06:35:09
    Hi Sarah,
    any chance you could share with me the full log please ? It's very odd that with 14GB free memory zephyr couldn't allocate a few MBs. Either something else was going on or it may be an issue with the specific hardware. However before telling you to run diagnostics like memetest and such, i'd like to see the log so i can investigate further if possible
    Thank you!
    • SarahC
      • Mar 2018
      • 30
      Sure thing....
      Here's the effect of the errors: https://imgur.com/IRoTES3
      Textured Mesh Generation
      Selected mesh: Mesh 3
      Texture size: 4096
      Image Resolution percent: 100 %
      Maximum number of vertices: Maximum
      Use multiband method: yes
      Maximum cameras per triangle: 1
      Number of selected cameras: 26
      • SarahC
        • Mar 2018
        • 30
        I've just remembered to tell you - I don't actually NEED the models of the bins. I was experimenting, and saw the error.
        So I'll provide my services at gaining clues and data as you require. If it's some odd hardware issue for me, no matter.
        But if I've been able to help make the software even better - I'm happy to help out. =)
          Hi Sarah,
          thank you for your followup! No worries, we're always happy to help and welcome all feedback
          It looks like it's either some hardware issue (system ram) or environment (i.e. some other software running in the background that may have been tampering with the memory). As a test, did you try to re-compute it after a windows reboot?
          • SarahC
            • Mar 2018
            • 30
            I haven't.
            I will tonight. =)
            It's unlikely that anyone would want to use the program like this (apart from me) - I tried opening the program while I was logged in via Remote Desktop. It errors with OpenGL not found.
            So, wondering what happens if the program's running already - I RD'd onto the machine - and it crashes Explorer.exe, which then reloads.
            I do dev work, and it got me wondering what mechanism was going wrong - several programs I use can open render windows inside a RD desktop. I wonder if it's CUDA? I have had no experience with those libraries so I've never RD'd with a program using CUDA.
              Keep us updated then
              As for the Remote Destkop, the problem is that microsoft's RDP doesn't support OpenGL acceleration. Unfortunately, if you wish to run software that requires 3D acceleration (such as zephyr) you need to use another remote desktop software, for example splashtop or logmein hamachi.
              Unfortunately you can not use Microsoft's RDP with Zephyr and the only solution is to use another software.
              • SarahC
                • Mar 2018
                • 30
                I wonder if VNC will work - I've not had chance to work on my project yet, but I plan to restart my machine after some processing completes, and my housemate also has a GTX970 in some workstation they have, so we can test that too. It might be a bug with the GTX drivers...
                  • 559
                  I confirm that realVNC, tightVNC and ultraVNC work fine. The problems with the openGL applications is only specific to Windows RDP.
                  • SarahC
                    • Mar 2018
                    • 30
                    Thanks Roberto!
                    Today is the day I reset my machine, and also install the Free version on my housemates Z820 which also uses a GTX970 card:
                    Discover powerful HP Workstations for demanding tasks. Explore high-performance desktops & laptops designed for professionals. Shop HP® Store UK.
                    I don't think Andrea was able to re-create the error based on his message. (Is that right Andrea?) Or perhaps he didn't have time.
                    So....... I'll assume it worked.
                    So.......
                    If it crashes on both machines , it may be the nVidia drivers/bug. Beg Andrea for a patch to cover for nVidia.
                    If it doesn't crash on the z8 but still on mine after the reboot - I'll compare drivers to ensure I've got latest.
                    I'll also run with as many start up programs disabled as possible.
                    If mine only crashes after all's disabled - get out Visual Studio, slap in the 3dF thread and JIT debug the swine! (But it's the weekend!)
                    If I fail at this task - likely, I don't read x86/64 assembly too well.........
                    I'll pinch my housemates Z820 and build the meshes on it.
                    I like finding and identifying bugs - I hate finding them and not working them out!
                    I also like chatting.
                      • 559
                      I also made some tests, but I was unable to replicate the bug / issue. From the log I can certainly tell it's not related to the gpu (as the gpu was not running on that part), but it seems due to memory or IO problems. Please let me know if you can replicate the problem on other machines as well.
                      I also like chatting and correcting bugs
                      • SarahC
                        • Mar 2018
                        • 30
                        I was able to reboot this morning! 45 days,wow....
                        The textured mesh generation causes CUDA to run out of memory.
                        Texture 4096,
                        100% resolution,
                        Vertices: Maximum,
                        Multiband: yes.
                        I'm guessing this is expected due to their being: Vertices : 25766103 / Triangles : 8588701, and me not setting the maximum number of vertices?
                        --- Log started ---
                        [05:17:37] Computing photoconsistency score...
                        [05:17:46] Vertices : 25766103 / Triangles : 8588701
                        [05:17:46] CUDA device: 1/1
                        [05:17:46] CUDA device name: GeForce GTX 970
                        [05:17:46] CUDA runtime version: 8.0
                        [05:17:46] CUDA driver version: 9.1
                        [05:17:46] CUDA free memory: 3297
                        [05:17:46] CUDA total memory: 4096
                        [05:17:46] CUDA blocks properties: 2147483647x65535x65535
                        [05:17:46] CUDA threads properties: 1024x1024x64 (max 1024)
                        [05:17:46] CUDA capabilities: 5.2
                        [05:17:46] CUDA runtime capabilities: 5.0
                        [05:17:55] Disable CUDA device : GeForce GTX 970 [ID 0] (not enough device memory)
                        [05:17:55] All CUDA devices are disabled. Computation will run on CPU.
                        [05:17:55] Preparing neighbors...
                        [05:17:56] Computing visibilities for camera '_89a8809.jpg'
                        [05:18:01] Computing visibilities for camera '_89a8810.jpg'
                        [05:18:06] Computing visibilities for camera '_89a8811.jpg'
                        [05:18:10] Computing visibilities for camera '_89a8812.jpg'
                        [05:18:16] Computing visibilities for camera '_89a8813.jpg'
                        [05:18:21] Computing visibilities for camera '_89a8814.jpg'
                        [05:18:25] Computing visibilities for camera '_89a8815.jpg'
                        [05:18:30] Computing visibilities for camera '_89a8816.jpg'
                        [05:18:34] Computing visibilities for camera '_89a8817.jpg'
                        [05:18:38] Computing visibilities for camera '_89a8818.jpg'
                        [05:18:43] Computing visibilities for camera '_89a8819.jpg'
                        [05:18:47] Computing visibilities for camera '_89a8820.jpg'
                        [05:18:52] Computing visibilities for camera '_89a8821.jpg'
                        [05:18:55] Computing visibilities for camera '_89a8822.jpg'
                        [05:18:59] Computing visibilities for camera '_89a8823.jpg'
                        [05:19:03] Computing visibilities for camera '_89a8824.jpg'
                        [05:19:07] Computing visibilities for camera '_89a8825.jpg'
                        [05:19:11] Computing visibilities for camera '_89a8826.jpg'
                        [05:19:14] Computing visibilities for camera '_89a8827.jpg'
                        [05:19:18] Computing visibilities for camera '_89a8828.jpg'
                        [05:19:22] Computing visibilities for camera '_89a8829.jpg'
                        [05:19:26] Computing visibilities for camera '_89a8830.jpg'
                        [05:19:30] Computing visibilities for camera '_89a8831.jpg'
                        [05:19:33] Computing visibilities for camera '_89a8832.jpg'
                        [05:19:37] Computing visibilities for camera '_89a8833.jpg'
                        [05:19:41] Computing visibilities for camera '_89a8834.jpg'
                        [05:20:37] Preparing image : '_89a8809.jpg'
                        [05:20:37] Preparing image : '_89a8822.jpg'
                        [05:20:39] Unable to load '_89a8809.jpg' file!
                        [05:20:39] Preparing image : '_89a8810.jpg'
                        [05:20:39] Unable to load '_89a8810.jpg' file!
                        [05:20:39] Preparing image : '_89a8811.jpg'
                        [05:20:40] Unable to load '_89a8811.jpg' file!
                        [05:20:40] Preparing image : '_89a8812.jpg'
                        [05:20:40] Preparing image : '_89a8823.jpg'
                        [05:20:41] Unable to load '_89a8823.jpg' file!
                        [05:20:41] Preparing image : '_89a8824.jpg'
                        [05:20:42] Preparing image : '_89a8813.jpg'
                        [05:20:43] Unable to load '_89a8813.jpg' file!
                        [05:20:43] Preparing image : '_89a8814.jpg'
                        [05:20:43] Preparing image : '_89a8825.jpg'
                        [05:20:45] Preparing image : '_89a8815.jpg'
                        [05:20:45] Preparing image : '_89a8826.jpg'
                        [05:20:47] Preparing image : '_89a8816.jpg'
                        [05:20:47] Preparing image : '_89a8827.jpg'
                        [05:20:49] Preparing image : '_89a8817.jpg'
                        [05:20:49] Preparing image : '_89a8828.jpg'
                        [05:20:51] Preparing image : '_89a8818.jpg'
                        [05:20:51] Preparing image : '_89a8829.jpg'
                        [05:20:53] Preparing image : '_89a8819.jpg'
                        [05:20:53] Preparing image : '_89a8830.jpg'
                        [05:20:55] Preparing image : '_89a8820.jpg'
                        [05:20:55] Preparing image : '_89a8831.jpg'
                        [05:20:57] Preparing image : '_89a8821.jpg'
                        [05:20:57] Preparing image : '_89a8832.jpg'
                        [05:20:59] Preparing image : '_89a8833.jpg'
                        [05:21:01] Preparing image : '_89a8834.jpg'
                        [05:21:03] +++ ERROR +++ (computation error)
                        [05:21:04] +++ ERROR +++ (computation error)
                        [05:21:04] Done.
                        [05:21:35] Computing blurriness...
                        • SarahC
                          • Mar 2018
                          • 30
                          It's ALL working now!
                          After restarting, and rebuilding the bins on "high" settings - I got an issue with memory allocation, which disabled CUDA.
                          BUT - the meshing and texturing completed fine, just without the CUDA acceleration.
                          I thought it was a bug - until I checked out the stats:
                          Triangles: 8,588,690
                          GPU usage hits 100% just rotating all those! I'm left with about 0.5 GB video RAM left, 3.4GB used... more than many games!
                          So yeah - the memory allocation problems were due to something just on my machine - I wonder if "RAM fragmentation" is a thing on GFX cards? I know memory requests in C require contiguous free memory.
                          My test memory problem was due to the HUGE mesh!
                          Thanks for listening everyone - I feel a bit awkward knowing now knowing it was my own PC's issue, and not the programs!
                            Hi Sarah,
                            there may be two different things at play here:
                            This may be due to this issue the GTX970 cards have. I think they partially fixed the issue by releasing newer bios, so although i cannot be 100% sure this is the cause, try updating the bios of your card if your vendor has made an update available, just so you can sleep happily. Seeing you report a ram usage sospiciously close to the 3.5 limit, i'd just thought i'd throw this here.
                            However, the other issue here
                            is actually unable to load the image data, either from disk (e.g. image no longer present for some reason) or from ram (e.g. bad ram stick).
