Matching two projects & Measuring
  • Furkan
    • May 2018
    • 18
    Hello Forum,
    I have to questions concerning the software 3DF Zephyr.
    1) Is it possible to put two different projects together in one new project? For example a subject which has a top and a bottom side... Can I take photos from the bottom side in one project and from the top side in another project so i can match them in a new project together? Is this possible?
    2) Is it possible to measure distances of some subject I want to measure? Is it for example possible to measure the diameter of the subject I attached down below?
    I would be happy for a quick answer.
    Best regards...
    Hi Furkan,
    Yes, both things are possible, but the control points/measurements and merge with control points features are included only in the PRO - AERIAL versions of Zephyr.
    You can have look at these tutorials that covers both questions:
    For measuring, you can also use a third party software to scale the model and make measurements. Please note that the reconstruction in Zephyr is always up to an unknown scale factor and you need at least one known distance or some control points to scale the model metrically before doing measurements.
