3DF Zephyr v.1.007
    3DF Zephyr v.1.007
    Changelog:
    - Fixed an issues during 3DF Samantha matching phase (improved accuracy)
    - Improve speed of 3DF Samantha matching phase
    - Fixed progress bar ETA
    - Speed improvements during keypoint extraction
    - Added Educational (for courses) version
    [!--:en--]The command line version 1.60 matches the one running in Zephyr v.1.007.
    - Improved speed and memory footprint with large datasets
    - Improved matching accuracy and speed
    - Improved autocalibration[!--:--][!--:it--]The command line version 1.60 matches the one running in Zephyr v.1.007.
      Roberto commented
      Editing a comment
      I've uploaded a modified versions at this address:
      x64
      x86
      The fix should work, but I haven't had time to test the new version properly yet.
      Let me know if you are having problems.
    • jamesm
      jamesm commented
      Editing a comment
      Thanks Roberto.
      I'm getting the tangential components reported now, but error (as given by image residuals on control point observations) has increased significantly. This could be an issue here though - I will check further and compare with my v1.5 results.
      All the best,
      Mike
    • jamesm
      jamesm commented
      Editing a comment
      Looks like the errors were a graphics card issue on the laptop - results look fine when processing was carried on a different machine.
      Thanks,
      Mike
  • jamesm
    • Mar 2013
    Hi Roberto,
    I am trying to use the new Samantha v1.60 (x64), but the downloaded file (19,426,711 bytes) won't unzip (the archive appears to be corrupt). The x84 version seems fine. Any suggestions?
    Many thanks,
    Mike
      Hi Mike,
      Thanks for reporting this. I've made an update yesterday evening to include a missing dll and it probably got corrupted during the upload. It should be ok now (size 19.618.399 bytes)
      • jamesm
        • Mar 2013
        Perfect. Thanks for the speedy response, it's running fine now.
        Mike
        • jamesm
          • Mar 2013
          Hi Roberto,
          Another query - which I think maybe a v1.60 change.
          I'm carrying out reconstructions, with auto-calibration and both radial and tangential distortion within the adjustment. I output the ppm files, but the tangential distortion coordinates no longer seem to be reporting as non-zero (or maybe they are not being adjusted?). I have previous ppm files in which tangential distortion was being reported fine. The ini file is below.... I'm hoping we can get the parameters to be written again?
          Many thanks,
          Mike
          [CameraCalibration]
          FocalX=4444.00
          FocalY=4444.00
          PrincipalPtX=2000
          PrincipalPtY=1500
          RadialDistK1=0
          RadialDistK2=0
          RadialDistK3=0
          RadialDistP1=0
          RadialDistP2=0
          Skew=0
          [Cuda]
          Device=0
          [Export]
          Bundlerv03=false
          CmvsPmvs2=false
          Ogrettha=false
          PlyTxt=true
          SingleTxtPPMs=true
          TextMatlab=false
          [Samantha]
          AdjustIntrinsic=true
          AdjustRadialDistortion=true
          AdjustTangentialDistortion=true
          ANNApproximationThreshold=0.0
          ANNNumberOfFeatures=500
          ANNNumberOfNeighbors=8
          CheckUpdates=true
          ConservativeBa=true
          FinalMaxReprojectionError=1.0
          FinalMinimumTrackLength=3
          ForceSequentialPipeline=false
          ImportKeypointsFromTxt=false
          KeypointMeanN=7500
          LinkageMinSearchRange=1
          LocalBa=true
          MaxBAIterations=200
          MinimumMatches=10
          MultithreadANN=true
          NumberOfMatchViews=0
          PointRecovery=true
          ProjectiveReconstruction=true
          ReprojectionThreshold=3.0
          StructSequence=0
          UseSymmetricMatches=true
          [Workspace]
          Path=F:\2013 James et al SfM accuracies\Prj
            I've checked and the Samantha parameter 'AdjustTangentialDistortion' has been simply unlinked from the new bundle adjustment functions in the command line version. I'll prepared a fixed version later today or tomorrow.
            Thanks
            Roberto
              x64
              x86
              • jamesm
                • Mar 2013
                Thanks Roberto.
                All the best,
                Mike
