Zephyr ignoring parts of UV
  • Stormy
    • Jun 2018
    • 11
    Hi, I'm encountering a quite frustrating problem. I have unwrapped a piece of wall on blender to reimport it in Zephyr, all import happened normally, but after reprojection it seems like Zephyr has ignored some parts of the UVs (see image below). I tried modifying the UVs back in Blender but it doesn't change anything, and I did other pieces of wall with the same process and it worked perfecly well! What could it be, how could I fix it?
    Thanks.
    Hi Stormy,
    did you move the model? you must not translate the model in blender, if that's the case, you should re-open the model in blender and put it back to its original point before exporting it again
    • Stormy
      • Jun 2018
      • 11
      I've merged some element made directly in blender (window cross) and it seems like the join command may affect the overall transformation of the object.
        I'm not a blender expert but it shouldn't affect it, unless maybe you set the newly created element as parent? If you find the culprit let us know
        • Stormy
          • Jun 2018
          • 11
          okay so now a new problem appear while trying to fix the first one. I export my mesh from blender, it's supposed to be one whole mesh. But when I import it into Zephyr, only the part I made is loaded! :/ The part imported from Zephyr to Blender is ignored..
            Make sure you have one single mesh, also no quads (they have been added in the current beta, so if you're on 3.702 only use triangles)
            • Stormy
              • Jun 2018
              • 11
              I'm on the 3.702 so I'm triangulating all exports. When you say one single mesh, it mean that it can have two different mesh, merged in a single object, right?
                Yes, that's what i mean!
                • Stormy
                  • Jun 2018
                  • 11
                  Hi, back from weekend, I did everything back and now it seem like Zephyr can't import my mesh, but I can't determine why. Here is the log:
                    Hi Stormy,
                    any chance you could share with me the mesh and project (zep+photos) ? This way is much easier for me to help you
                    • Stormy
                      • Jun 2018
                      • 11
                      There's 2Go of RAW photos so It will take time to upload but yes I can do this!
                        Great! Do you have a service you can use or shall i open up a space on our server for you?
                        • Stormy
                          • Jun 2018
                          • 11
                          I'm uploading everything on Google Drive and I'll send you a download link when it's done!
                          • Stormy
                            • Jun 2018
                            • 11
                            Here is the link to a folder with photos, zep file and last obj meshes used.
                            To use Google Drive, you need to use a supported web browser. Learn what a browser is, which browser you use, and how to update to the latest version. Option 1: Find the update for your browser To
