Stitching photos
  • Safia
    • Jul 2018
    • 14
    Stitching photos
    Now if I devided the place which I want to generate it 3d via photogrammetry into 2 regions and after generating each region I want to stitch them together.
    Is there any way in 3DF to do that?
    ?Thanks ?
    • 1350
    Hello Safia,
    Yes, you can in 3DF Zephyr Pro and Aerial.
    You can either:
    - process the sparse cloud in both projects, then merge them togheter either via control points or nearby cameras. Then you can process a single dense point cloud
    OR
    - process the dense clouds separately, then merge the two zep files togheter, then merge the two point clouds
    You may also use the direct merge option if they are already in the same (correct) reference system.
    • Safia
      • Jul 2018
      • 14
      Thank you so much
