Alignement errors...
    • 1350
    #15
    Hi Yoruk,
    yes, absolutetly, it's actually a commonly used acquisition strategy for acquisiton.
    As a side note, if you want to mask it out, you can use masking only from the MvS phase onward, if you check the "ignore masking during SfM" option in the new project wizard.
    • Yoruk
      • Jul 2018
      • 28
      #16
      I have quite better results with reducing the exposure. But :
      -I have issues with the automatic masking procedure. When enabling the "turn table" feature, the automatic feature works absolutely great until the 10th picture. After this one, the software doesn't find the model...? I had to manually finish the cropping for all pictures.
      -the alignment is strange. So I have 72 pictures, but I can use only 50 ;-). When putting images 1...50, it doesn't works, but 26..72 seems to wok better.
      If I upload the pics and the masks on the FTP, could you please take a look at them ?
      Many thanks !
        • 1350
        #17
        Hi Yoruk,
        the turntable mode simply expects the background to stay the same for a great part, so that it can transfer easily the strokes. If the scene changes a lot (e.g. you moved the camera) then it's perfectly normal that you'll have to adjust the strokes accordingly. Please note you can clear all with the eraser icon.
        Sure, please go ahead and upload the images, i will have a look at them.
        • Yoruk
          • Jul 2018
          • 28
          #18
          I uploaded the pictures and the BIM files into the "craft" folder. Thank you !
            • 1350
            #19
            Hi Yoruk,
            unfortunately due to time constraints i coudln't check your new upload this week. I'll do it as soon as i can and report back.
            • Yoruk
              • Jul 2018
              • 28
              #20
              Many thanks ! Don't worry for the delay.
                • 1350
                #21
                Hi Yoruk,
                i finally had a chance to try your dataset. Which settings did you use? I used 1-50 with Close Range/Default and everything was oriented correctly. Also using everything, all 72 were processed correctly.
                Am I missing something?
                Best,
                Andrea
                • Yoruk
                  • Jul 2018
                  • 28
                  #22
                  Well...great ! This is great news. Thanks for taking time to take a look at my issues.
                  So I'll try again with 1-50...
                  With the 72 pictures, did you try to compute the final model ?
                    • 1350
                    #23
                    • Yoruk
                      • Jul 2018
                      • 28
                      #24
                      Is it possible to request a demo version of the "3DF Zephyr Lite" version ?
                      I really want to try my model with the 50 pictures.
                      (EDIT : got it, it's here : https://www.3dflow.net/3df-zephyr-ev...-download-page )
                        • 1350
                        #25
                        Hi Yoruk,
                        when installing Zephyr Lite for the first time, you automatically get 14 days of free trial. If you need few more days to try it more, just let me know.
                        Andrea
                        • Yoruk
                          • Jul 2018
                          • 28
                          #26
                          Thanks ! I need more experiments before buying.
                          Can I use both the trial and the free version on the same computer ?
                            • 1350
                            #27
                            Yes absolutetly, they are independent and can co-exist on the same machine
                            • Yoruk
                              • Jul 2018
                              • 28
                              #28
                              I have very nice results with the 72 photos.
                              Of course the top of the model is missing, but I see how to solve it (As explained, I will try to get an other series of pictures).
                              But I have strange artifacts around the feets :
                              Can I manually solve this ? (by cropping the model ?) or again this will be solved with an other series of pictures ?
                              Thanks.
