Help texture error obj + mtl Meshmixer
  • Naderfagundes
    • Jul 2018
    • 6
    Hello. Please, i need some help. I was using the version 4.0 of 3df Zephyr free, exporting my mesh with textures as OBJ + MTL and opening in Meshmixer without any error. ( PS. Calculating with only one texture). After this last update when i try to load my files in meshmixer it can't find the jpg. Its loads my mtl and can't find the jpg.
    • 559
    Hi Naderfangundes,
    we shouldn't have changed anything on that part with the last update. I made a quick test, and the obj is exported correctly. Can you please open the obj with another viewer (for example, meshlab?)?
    Do you see the texture .jpg files exported in the same directory? Are the texture names in the mtl file correct? Open it in notepad and check if the name .jpg corresponds to the same texture file in the directory.
    To exclude reading problems in meshmixer, please also try to export on a simple folder without any special char (like c:\test\sample.obj)
    • Naderfagundes
      • Jul 2018
      • 6
