3DF Zephyr v.1.009
    3DF Zephyr v.1.009
    Performance changelog:
    + New MVS (densification) procedure in Cuda.
    + Color computation and image undistortion speed up in mesh and point cloud.
    New Features Changelog:
    + Novel Visibility computation for meshes (improve both texture and orthophoto generation). Warning: to use it you have to generate a mesh (only the mesh) again inside zephyr.
    + Multiband tecnique for both texture and orthophoto generation.
    + It is now possible to choose how many cameras per pixel to use in texture and orthophoto generation.
    + It is now possible to choose which cameras to use during orthophoto and texture generation.
    + It is now possible to simplify the mesh before exporting the textures
    + It is now possible to specify the size of the generated texture.
    + Progress bar now shows button 'Show Log', 'Minimize', and 'Pause' (Resume).
    + Added tutorial and forum shortcut from the help menu.
    + Mesh Visibility information is now compressed and occupy less memory (both ram and .zep file)
    Accuracy Changelog:
    + Improved accuracy in keypoint extraction.
    Bugfix changelog:
    + fixed a bug with 4 channels tiff
    + fixed a bug in stereo computation (caused crashes with cuda)
    + fixed a minor bug in the texture generation process (improved accuracy)
    + fixed a bug in visibility computation (improved accuracy on orthophoto and texture generation)
    + fixed a bug in visibility computation that caused missing triangles (holes) in the extracted mesh
    + thumbnails in the rendering windows are now undistorted
    + improved out of memory managment
    + minor ui/typos fixes
    The new version of 3DF Zephyr is going to be released today.
    Here's the full changelog:
    + Parameters are now fully exposed and can be imported through xml.
    + Added texture support for ply
    + Removed duplicated and dangling vertices during texture exporting
    + Added noise control slider for stereo computation.
    + Added a remesh checkbox to enable/disable remeshing when exporting a mesh.
    + Smoothness can be controlled more smoothly (via slider)
    + Added an alpha mask to dem as a separate tiff page.
    + Corrected a bug on mesh simplification during exporting.
    + Fixed a bug on mesh simplification. Improved mesh visibilty computation and post-processing.
    + Fixed a problem with 'cropped' images on control points selection.
    + Fixed a crash occurring in stereo on certain configurations.
    + Fixed a problem with stereo accuracy using low discretization.
    + Visibility Computation fixes.
    + Orthophoto (and dem) is now properly computed only where the mesh exists
    + Fixed normal computation problem for meshes
    + Added check for opengl 1.4
    • jimmyrig
      • May 2014
      http://s13.postimg.org/yi5hlo3id/Zephyr_Eval_CUDA_Error.png
      GTX 780 with latest WHQL Drivers from NVidia.
        Andrea Alessi commented
        I can confirm that there are issues with the non - quadro family cards and Cuda 5.5 with the latest driver from nVidia. Rolling back to previous version ( [ 335.x ) seems to fix it (can't try it on the whole non-quadro family out there though =) )
        Cuda6 support has been added to the current beta and will be available in the next stable release as well.
      • jimmyrig
        jimmyrig commented
        [!--:en--]Looks like the newest fix both sees my 780 and CUDA works with the latest WHQL drivers
        http://s18.postimg.org/l3tn7e8ih/CUDA_Works.png
        On a side note, thank you for the trial key! I'm not doing any commercial stuff, just working through the tutorials for now, definately a cool app for sure [!--:--][!--:it--]Looks like the newest fix both sees my 780 and CUDA works with the latest WHQL drivers
        Great to hear that
        No problem at all! Feel free to post further and/or email me logs if you need further assistance!
    • jimmyrig
      • May 2014
      [19:22:15] Initialize Workspace
      [19:22:15] Loading Localization
      [19:22:15] Preparing UI
      [19:22:15] Initialize Rendering
      [19:22:15] Installing plugin: GL RenderSystem
      [19:22:15] OpenGL Rendering Subsystem created.
      [19:22:15] Plugin successfully installed
      [19:22:15] CPU Identifier & Features
      [19:22:15] -------------------------
      [19:22:15] * CPU ID: GenuineIntel: Intel(R) Core(TM) i7-4930K CPU @ 3.40GHz
      [19:22:15] * SSE: yes
      [19:22:15] * SSE2: yes
      [19:22:15] * SSE3: yes
      [19:22:15] * MMX: yes
      [19:22:15] * MMXEXT: yes
      [19:22:15] * 3DNOW: no
      [19:22:15] * 3DNOWEXT: no
      [19:22:15] * CMOV: yes
      [19:22:15] * TSC: yes
      [19:22:15] * FPU: yes
      [19:22:15] * PRO: yes
      [19:22:15] * HT: no
      [19:22:15] *** Starting Win32GL Subsystem ***
      [19:22:15] Registering ResourceManager for type Texture
      [19:22:15] Registering ResourceManager for type Font
      [19:22:15] GLRenderSystem::_createRenderWindow "RenderWindow_4981960", 100x30 windowed miscParams: colourDepth=16 depthBuffer=false externalWindowHandle=4981960
      [19:22:15] GL_VERSION = 4.4.0
      [19:22:15] GL_VENDOR = NVIDIA Corporation
      [19:22:15] GL_RENDERER = GeForce GTX 780/PCIe/SSE2
      [19:22:15] GL_EXTENSIONS = GL_AMD_multi_draw_indirect GL_AMD_seamless_cubemap_per_texture GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_bindless_texture GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_compute_shader GL_ARB_compute_variable_group_size GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_indirect GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_indirect_parameters GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counters GL_ARB_shader_bit_encoding GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_query_buffer_object GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_sparse_texture GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_image_load_store GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_debug GL_KTX_buffer_region GL_NV_bindless_multi_draw_indirect GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_square GL_NV_compute_program5 GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_draw_texture GL_NV_ES1_1_compatibility GL_NV_ES3_1_compatibility GL_NV_explicit_multisample GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_gpu_program4_1 GL_NV_gpu_program5 GL_NV_gpu_program5_mem_extended GL_NV_gpu_program_fp64 GL_NV_gpu_shader5 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_atomic_counters GL_NV_shader_atomic_float GL_NV_shader_buffer_load GL_NV_shader_storage_buffer_object GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_attrib_integer_64bit GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_NVX_nvenc_interop GL_NV_shader_thread_group GL_NV_shader_thread_shuffle GL_KHR_blend_equation_advanced GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
      [19:22:15] Supported WGL extensions: WGL_ARB_buffer_region WGL_ARB_create_context WGL_ARB_create_context_profile WGL_ARB_create_context_robustness WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_multisample WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_pixel_format_float WGL_ARB_render_texture WGL_ATI_pixel_format_float WGL_EXT_create_context_es_profile WGL_EXT_create_context_es2_profile WGL_EXT_extensions_string WGL_EXT_framebuffer_sRGB WGL_EXT_pixel_format_packed_float WGL_EXT_swap_control WGL_EXT_swap_control_tear WGL_NVX_DX_interop WGL_NV_DX_interop WGL_NV_DX_interop2 WGL_NV_delay_before_swap WGL_NV_float_buffer WGL_NV_multisample_coverage WGL_NV_render_depth_texture WGL_NV_render_texture_rectangle
      [19:22:15] ***************************
      [19:22:15] *** GL Renderer Started ***
      [19:22:15] Registering ResourceManager for type GpuProgram
      [19:22:15] GLSL support detected
      [19:22:15] GL: Using GL_EXT_framebuffer_object for rendering to textures (best)
      [19:22:15] FBO PF_UNKNOWN depth/stencil support: D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_L8 depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_A8 depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_A4L4 depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_BYTE_LA depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_R5G6B5 depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_B5G6R5 depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_A4R4G4B4 depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_A1R5G5B5 depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_R8G8B8 depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_B8G8R8 depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_A8R8G8B8 depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_B8G8R8A8 depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_A2R10G10B10 depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_A2B10G10R10 depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_FLOAT16_RGB depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_FLOAT16_RGBA depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_FLOAT32_RGB depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_FLOAT32_RGBA depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_X8R8G8B8 depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_X8B8G8R8 depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_SHORT_RGBA depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_R3G3B2 depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_FLOAT16_R depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_FLOAT32_R depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_FLOAT16_GR depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_FLOAT32_GR depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] FBO PF_SHORT_RGB depth/stencil support: D0S0 D0S8 D16S0 D24S0 D32S0 Packed-D24S8
      [19:22:15] [GL] : Valid FBO targets PF_UNKNOWN PF_L8 PF_A8 PF_A4L4 PF_BYTE_LA PF_R5G6B5 PF_B5G6R5 PF_A4R4G4B4 PF_A1R5G5B5 PF_R8G8B8 PF_B8G8R8 PF_A8R8G8B8 PF_B8G8R8A8 PF_A2R10G10B10 PF_A2B10G10R10 PF_FLOAT16_RGB PF_FLOAT16_RGBA PF_FLOAT32_RGB PF_FLOAT32_RGBA PF_X8R8G8B8 PF_X8B8G8R8 PF_SHORT_RGBA PF_R3G3B2 PF_FLOAT16_R PF_FLOAT32_R PF_FLOAT16_GR PF_FLOAT32_GR PF_SHORT_RGB
      [19:22:15] RenderSystem capabilities
      [19:22:15] RenderSystem Name: OpenGL Rendering Subsystem
      [19:22:15] GPU Vendor: nvidia
      [19:22:15] Device Name: GeForce GTX 780/PCIe/SSE2
      [19:22:15] Driver Version: 4.4.0.0
      [19:22:15] * Fixed function pipeline: yes
      [19:22:15] * Hardware generation of mipmaps: yes
      [19:22:15] * Texture blending: yes
      [19:22:15] * Anisotropic texture filtering: yes
      [19:22:15] * Dot product texture operation: yes
      [19:22:15] * Cube mapping: yes
      [19:22:15] * Hardware stencil buffer: yes
      [19:22:15] - Stencil depth: 8
      [19:22:15] - Two sided stencil support: yes
      [19:22:15] - Wrap stencil values: yes
      [19:22:15] * Hardware vertex / index buffers: yes
      [19:22:15] * Vertex programs: yes
      [19:22:15] * Number of floating-point constants for vertex programs: 1024
      [19:22:15] * Number of integer constants for vertex programs: 0
      [19:22:15] * Number of boolean constants for vertex programs: 0
      [19:22:15] * Fragment programs: yes
      [19:22:15] * Number of floating-point constants for fragment programs: 512
      [19:22:15] * Number of integer constants for fragment programs: 0
      [19:22:15] * Number of boolean constants for fragment programs: 0
      [19:22:15] * Geometry programs: yes
      [19:22:15] * Number of floating-point constants for geometry programs: 2048
      [19:22:15] * Number of integer constants for geometry programs: 0
      [19:22:15] * Number of boolean constants for geometry programs: 0
      [19:22:15] * Tesselation Hull programs: no
      [19:22:15] * Number of floating-point constants for tesselation hull programs: 0
      [19:22:15] * Number of integer constants for tesselation hull programs: 0
      [19:22:15] * Number of boolean constants for tesselation hull programs: 0
      [19:22:15] * Tesselation Domain programs: no
      [19:22:15] * Number of floating-point constants for tesselation domain programs: 0
      [19:22:15] * Number of integer constants for tesselation domain programs: 13824
      [19:22:15] * Number of boolean constants for tesselation domain programs: 12336
      [19:22:15] * Compute programs: no
      [19:22:15] * Number of floating-point constants for compute programs: 30752
      [19:22:15] * Number of integer constants for compute programs: 12576
      [19:22:15] * Number of boolean constants for compute programs: 12848
      [19:22:15] * Supported Shader Profiles: arbfp1 arbvp1 fp20 fp30 fp40 glsl gp4fp gp4gp gp4vp gpu_fp gpu_gp gpu_vp nvgp4 vp30 vp40
      [19:22:15] * Texture Compression: yes
      [19:22:15] - DXT: yes
      [19:22:15] - VTC: yes
      [19:22:15] - PVRTC: no
      [19:22:15] - ATC: no
      [19:22:15] - ETC1: no
      [19:22:15] - ETC2: no
      [19:22:15] - BC4/BC5: no
      [19:22:15] - BC6H/BC7: no
      [19:22:15] * Scissor Rectangle: yes
      [19:22:15] * Hardware Occlusion Query: yes
      [19:22:15] * User clip planes: yes
      [19:22:15] * VET_UBYTE4 vertex element type: yes
      [19:22:15] * Infinite far plane projection: yes
      [19:22:15] * Hardware render-to-texture: yes
      [19:22:15] * Floating point textures: yes
      [19:22:15] * Non-power-of-two textures: yes
      [19:22:15] * 1d textures: yes
      [19:22:15] * Volume textures: yes
      [19:22:15] * Multiple Render Targets: 8
      [19:22:15] - With different bit depths: yes
      [19:22:15] * Point Sprites: yes
      [19:22:15] * Extended point parameters: yes
      [19:22:15] * Max Point Size: 2047
      [19:22:15] * Vertex texture fetch: yes
      [19:22:15] * Number of world matrices: 0
      [19:22:15] * Number of texture units: 16
      [19:22:15] * Stencil buffer depth: 8
      [19:22:15] * Number of vertex blend matrices: 0
      [19:22:15] - Max vertex textures: 32
      [19:22:15] - Vertex textures shared: yes
      [19:22:15] * Render to Vertex Buffer : yes
      [19:22:15] * Hardware Atomic Counters: no
      [19:22:15] * GL 1.5 without VBO workaround: no
      [19:22:15] * Frame Buffer objects: yes
      [19:22:15] * Frame Buffer objects (ARB extension): no
      [19:22:15] * Frame Buffer objects (ATI extension): no
      [19:22:15] * PBuffer support: yes
      [19:22:15] * GL 1.5 without HW-occlusion workaround: no
      [19:22:15] * Vertex Array Objects: no
      [19:22:15] * Separate shader objects: no
      [19:22:15] DefaultWorkQueue('Root') initialising on thread main.
      [19:22:15] Particle Renderer Type 'billboard' registered
      [19:22:15] Creating resource group 3DFRenderer
      [19:22:15] Added resource location './' of type 'FileSystem' to resource group '3DFRenderer'
      [19:22:15] Added resource location './data.arc' of type 'Zip' to resource group 'General'
      [19:22:15] Parsing scripts for resource group 3DFRenderer
      [19:22:15] Finished parsing scripts for resource group 3DFRenderer
      [19:22:15] Creating resources for group 3DFRenderer
      [19:22:15] All done
      [19:22:15] Parsing scripts for resource group Autodetect
      [19:22:15] Finished parsing scripts for resource group Autodetect
      [19:22:15] Creating resources for group Autodetect
      [19:22:15] All done
      [19:22:15] Parsing scripts for resource group General
      [19:22:15] Parsing script proper-definitions.fontdef
      [19:22:15] Finished parsing scripts for resource group General
      [19:22:15] Creating resources for group General
      [19:22:15] All done
      [19:22:15] Parsing scripts for resource group Internal
      [19:22:15] Finished parsing scripts for resource group Internal
      [19:22:15] Creating resources for group Internal
      [19:22:15] All done
      [19:22:15] Loading resource group '3DFRenderer' - Resources: 1 World Geometry: 1
      [19:22:15] Finished loading resource group 3DFRenderer
      [19:22:15] Available physical memory: 60027 Mb.
      [19:22:15] 3DF Zephyr Evaluation v. 1.010 Ready.
      [19:25:14] Cleaning up temporary folder: C:/Users/JIMMYR~1/AppData/Local/Temp/3DF Zephyr Evaluation/
      Thats the entire log. Thanks
