Show overlapping of photographs in each model.
  • josenunez
    • Aug 2018
    Hello!
    I'm doing a sensitivity analysis on the same object but decreasing the photographs in each of the models.
    What I need is to obtain the overlap that the photographs have in each model. Is this possible and how?
    Thanks!!
    • 559
    Hi Jose,
    I'm not sure if this is what you are looking for, but you can filter the dense/sparse point cloud based on the number of cameras that view those points (selections by point tool). In this way, you can select for example the points that are seen for example by more than 3 or 10 cameras. Alternatively, From the Tools->workspace->camera stats, you can order the cameras by the number of visible points. Although not precisely what you are looking for, this is somewhat related to the area of the model viewed by each camera. Finally, the confidence tool (only pro/aerial version) can show you region with high visibility and scores.
