Using the correct CPU
  • LiNo
    • 44
    Hi, I have been running a number of projects with some success, but I was just looking through a recent log file and I noticed this:
    [15:55:42] CPU Identifier & Features
    [15:55:42] -------------------------
    [15:55:42] * CPU ID: GenuineIntel: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
    [15:55:42] * SSE: yes
    [15:55:42] * SSE2: yes
    [15:55:42] * SSE3: yes
    [15:55:42] * SSE41: yes
    [15:55:42] * SSE42: yes
    [15:55:42] * MMX: yes
    [15:55:42] * MMXEXT: yes
    [15:55:42] * 3DNOW: no
    [15:55:42] * 3DNOWEXT: no
    [15:55:42] * CMOV: yes
    [15:55:42] * TSC: yes
    [15:55:42] *INVARIANT TSC: yes
    [15:55:42] * FPU: yes
    [15:55:42] * PRO: yes
    [15:55:42] * HT: no
    This is fine for the CPU, but is there something equivalent in the log related to the GPU? (I just want to make sure that Zephyr is running / recognising the GPU.)
    Regards,
    Noel.
    • 1380
    Hi Noel,
    yes, you will find information on the gpu as well. However, if you suspect your GPU is not being used, you need to check in the actual computation. for example
    [12:33:48] [CPU 0] [Record_2016-03-19_21-31-05.tiff] Loading image...
    means that in a certain step, the CPU has been used, either because it was not available as a GPU action (not everything can be run on GPU) or because your GPU was not enabled. In this case, by nature, this step can be only run in CPU.
    [12:33:48] [GPU 0] [Record_2016-03-19_21-31-05.tiff] Detecting keypoints...
    In this case, you can see that the first GPU (GPU0) is being used by zephyr for the actual computation.
    • LiNo
      • 44
      Thanks Andrea. Does the "0" mean anything (CPU 0 / GPU 0)?
      Regards,
      Noel.
        • 1380
        yes, it means it's the first one.
        so for example, if you had two GPUs, you would see
        [GPU 0] something...
        [GPU 1] something...
        where 0 is the first gpu and 1 is the second gpu, and so on. Same for CPUs.
        • LiNo
          • 44
          Great. Thanks again Andrea.
