mesh failed
  • felipe lermanda
    • Jun 2018
    mesh failed
  • felipe lermanda
    • Jun 2018
    I found the solution for the warning
      • 1366
      Hello Felipe,
      it may be possible that "case limit" datasets work with a version and not with another, as our technology changes and evolves with every update.
      However, if you changed some parameter in the custom view and then switched to presets/advanced, please note that some settings may not have been reset. Either reset the settings (right click -> reset to default) or use the "restore zephyr to factory settings" from the option menu.
