Camera rotation matrix
  • Sendan
    • May 2018
    Hey guys,
    im trying at the moment to export the camera externals and internals for further processing via matlab.
    There are two options about to choose:
    1. Export internal and external paramteres as txt
    2. Export intrinsics and extriniscs as xmp
    For a specific camera i get the folowing values for the rotationmatrix
    1)
    ### First Axis of Rotation X, Second Axis of Rotation Y, Third Axis of Rotation Z
    "180430_140521_1.png" 0.194836 -112.099455 586.355392 23.052650 -0.210098 90.666832
    So the Rotationmatrix R should be calculated by
    R=RotZ(gamma)*RotY(beta)*RotX(alpha)
    with
    alpha=23.052650
    beta=-0.210098
    gamma=90.666832
    when i calculate the above equation with matlab i get:
    -0.0116 -0.9201 0.3916
    R = 0.9999 -0.0121 0.0012
    0.0037 0.3916 0.9201
    2)
    -0.011638076 0.92009981 0.39151104
    R = 0.99992555 0.0092730188 0.0079310836
    0.0036668993 0.3915742 -0.92013923
    Both rotationmatrices are similar but not equal...
    Can you answer me where my error is?
    Kind regards
    Michael
    Hi Michael,
    not sure if i understood, but it looks good to me. Are you sure you set matlab to print more than 4 decimals ?
    • Sendan
      • May 2018
      Thx for the fast reply
      Its not only about the values:
      Element(row=1,column=2) from 1) is negative
      Element(row=1,column=2) from 2) is positive
        the transformation looks good, but most likely the axis convention you are using is different than the one in zephyr, so simply invert them accordingly to your reference system
