Blurry Textures, hmm?
  • Nedo
    3Dflow Cup 2018 winner
    • Nov 2016
    • 71
    Hi there, with one of my latest project i have problems with blurry textures, some parts are sharp, others blurry,
    i then change different settings for the texture creating, what happens is, other parts getting blurry and some others sharp.
    I just can't get everywhere sharp. Could this be because i used a low aperture with my camera, front is sharp, background less sharp.
    All pictures worked for creating a complete point densecloud without a problem, but maybe this kind of photos dont work for texturing?
    Would it be possible to mask out the blurry Photos for texturing? The option to use all cameras or just a few dont help me here, the photos are so small
    i cant see wich to use or not. I also decimated the Model in Zbrush and first thought its becasue of this, but same thing happen with the original Zephyr model.
    I tested the same photos with different photogrammetry apps and dont get blurry textures on the model.
    i attached 2 JPG's for you where you can see the different blurry parts.
    Hey Nedo! Did you try texturing with the experimental blurriness weighting? You could try masking out the blurry parts, but that sounds like a lot of manual labor. If you can share the dataset that would help a lot to figure out where the problem is
    - Hope you're well!
