About the quality of the photos
  • Nightingale
    • May 2018
    • 17
    Hi everyone !
    I am facing some issues with alignment. The rate of photos good for alignment is about 80%.
    I would like to know if my photos are OK or not.
    Here 2 samples.
    Thank you very much for expertise.
  • Nightingale
    • May 2018
    • 17
    I got a textured bust from 3DF Zephyr.
    I exported it to Maya - FBX).
    Here are the results textured and not textured.
    As we take a look at the textured mesh, we could think that result is good.
    As we take a look at the mesh, we see a lack of details.
    The question is : could we do it better ? For example with a better camera (DSLR, better focus, better resolution). I'm using Sony RX100 iv.
    What is the average resolution we could get ?
    For Information, the details on the hair are about 2 mm wide and they are not visible.
    In this case, the normal map from HP to LP won't have a lot of details.
    What can we do ?
    Thanks.
      Hi nightingale,
      shooting indoors is always a challenge. You would certainly get better results from better photos / better equipment.
      Since the object is small, i would try moving it outside on an overcast day - natural light is easier on camera sensors and would probably result in a better model.
      Hard to tell however if there are other issues without looking at thefull dataset.
        Hi Nightingale - Following up from Andrea, I too would recommend shooting outdoors on an overcast (but bright) day - If you need to shoot indoors it can very expensive very quickly (I run a small 3D scanning studio) - You need lights, a decent camera, a turntable along with other bits and pieces.
        So to answer your question directly - Yes you can do better - you can always do better! It just gets harder and harder to get better results. - Your camera is decent, ideally you'd have a DSLR which you can swap lenses on, but working with what you've got, you need to make sure you don't zoom in and out at all - Multiple focal lengths can lead to sub-standard 3D reconstructions.
        Along with the data-set if you could provide us with some information about the camera settings that would be great and will show where your bottleneck/s are. - This information SHOULD be attached to the images, but there's a chance the metadata is missing.
        2mm is totally achievable 1mm and even less is also achievable, but as I mentioned before, you need to work really hard to ensure all your setup and settings are ideal!
