Zephyr Free Tutorial
  • Hebbster
    • Oct 2018
    I'm trying to evaluate Zephyr vs Agisoft & thought I would start w/ the tutorial (https://www.3dflow.net/technology/do...ls-3df-zephyr/) using 3DF Zephyr Free to get a better feel of the differences & if it's worth it. Thought I had read that the best place to start was using the tutorial. Yet when I download the dataset recommended in the tutorial it has 65 images which is over the 50 image limit in the free version.
    Should I be using a different dataset than recommended in the tutorial or is there a different tutorial to use? Don't use all the images? (if so then indicating which to drop would be useful)
    • 685
    Hey Hebbster -
    https://www.3dflow.net/3df-zephyr-ev...download-page/ - Grab a 14 day version of 3DFlow Zephyr Lite That way you can use all the images and there aren't any of the limitations imposed by the Free version.
      • 1350
      On a side note, if you still want to try without installing also 3DF Zephyr lite you can also use the dismal souvenir dataset from the masking tutorial (but make sure to follow the masking instructions too!).
      The cherub will also work with less images, it will be less detailed but you can safely remove 15 random images
