About control points
  • nick_2
    • Nov 2018
    Hi everyone !
    I don't know the meaning of constraints when setting control points.
    What's different when checking the constraint checkbox and not doing it?
    Thank you in advance for your help.
    • 685
    Good question! - I have no idea but I'm curious too!
      • 1350
      Hi Nick,
      constraints will drive the reconstruction to the desired solution you set using constraints.
      This is especially useful when you, say, get a sparse point cloud and you see that there are some wrongly placed cameras. You can then set control points and re-run the reconstruction/optimize camera paremeters to guide zephyr to the desired solution - and if you want the solution to also have specific coordinates (e.g. from a GPS device) you can set them as well.
      Controls are what their name says - just a control. It will not be considered when reconstructing as a constraint, but will still tell you which is the residual between the computed coordinate and your expected coordinate, so that you are able to measure accuracy/errors.
