Silent Install
  • PhilHudson
    • Nov 2018
    Silent Install
    Hi
    I need to deploy Zephyr Aerial to multiple machines via SCCM.
    Can script the silent install and uninstall ok - however cannot figure out how to activate it without user interaction
    Any command switches to bake that info in? either from the install or a (one time) run of Zephyr?
    thanks
    -Phil
    • 1372
    Hello Phil,
    unfortunately, user interaction is required for activation!
    Cheers,
    Andrea
    • rbos
      • Nov 2019
      Allow me to express my profound annoyance with this inexcusable lack of functionality. Some of us have better things to do than babysit a software installation on a dozen computers. I will be recommending against this software.
      edit: I'm wrong, see below.
        Hi Rbos,
        Thank you for your feedback!
        Please note that you can install the software "silently", by using the /Silent or /VerySilent switches from an administrator command line. The original post was about activation, which can be done by any user by inputting the serial key number on the first run (required only for the lite/pro/aerial versions). The software is activated to all users once done.
        Cheers,
        Roberto
        • rbos
          • Nov 2019
          Ah, thanks. Sorry for that. I didn't do much more research than a basic google about silent installation, and obviously misread. I should have been more patient.
