Cupcakes
    • 1349
    #15
    Yes that is the most common workflow, using control points : https://www.3dflow.net/technology/do...es-3df-zephyr/
    • CG-Guy
      • Apr 2018
      • 151
      #16
      Hey! Glad you liked them
      I usually measure the real thing then I use 3ds Max or Maya which allows to construct in real world scale be it metric or standard then just create a cube with those dimensions and scale it up or down to get everything consistent.
      This is my last step in creating low polygon versions since your high poly and low need to be in same 0,0,0 position and scale to transfer the details such as the PBR maps diffuse, normal map and ambient occlusion. I create the specular and gloss from scratch.
      Blender 3D also does this and it's free 3d program (I don't use it because I've used 3ds and maya (formally called Alias) since 1994.
      • CG-Guy
        • Apr 2018
        • 151
        #17
        Here's the latest and greatest - low poly - PBR Cupcakes - let me know if they look ok
        Thanks
ID:	4271Click image for larger version
ID:	4272Click image for larger version
ID:	4273Click image for larger version
ID:	4274Click image for larger version
        • AvionAvionics
          • Nov 2017
          • 76
          #18
          They look so real and i hate you for it lol
          • CG-Guy
            • Apr 2018
            • 151
            #19
            I've been doing 3d for so long it's easy, but with time and dedication and zeal you can do anything you want. (And 3dflow of course)
              • 685
              #20
              Hey Victor, you only need two control points for scaling a scene - So if for example, you draw two dots on your subject, measure that real world difference, process the scan, pick out those reference control points in Zephyr and set the distance to whatever the measurements were - et voila! - Please note, this functionality is only available in Pro/Aerial.
              You can set scales in other programs (like meshlab for example) by picking points on the mesh and scaling, but picking points in Zephyr through the photographs will yield much more accurate results.
              • AvionAvionics
                • Nov 2017
                • 76
                #21
                I can attest to the 2 control points in Zephyr for proper scaling of a car, it works great.
                  • 685
                  #22
                  EDIT: - I repeated myself because I didn't see that this comment thread spanned to page 2 - thought I was going crazy. Heh.
                  • CG-Guy
                    • Apr 2018
                    • 151
                    #23
                    Here's the final I came up with in a box - The last 2 pics are AR spawning it on the coffee table
ID:	4334Click image for larger version
ID:	4335Click image for larger version
ID:	4336Click image for larger version
                    • AvionAvionics
                      • Nov 2017
                      • 76
                      #24
                      Nice, that looks amazing. I am guessing you are using an Image target in the form of the magazine cover to spawn the Cupcakes?
                      Looks great though man.
                      • CG-Guy
                        • Apr 2018
                        • 151
                        #25
                        Actually the newer way is Google ARCore surface detection.
                        It scans for flat surfaces so images are not required. Most newer android phones support it. Makes it easier to drop art anywhere into real world
                        • jadi
                          • Dec 2022
                          CG-Guy I must admit that those are amazing images of cupcakes. I also have a website for cupcake delivery in Adelaide and would appreciate it if you could contact me since we need high quality images of our cupcakes. Thank you.
                            • 1349
                            #27
                            In case this was a genuine comment, I've edited it to remove the link to the company. If CG-Guy is interested he can reach out in private. Please do not use the forum to SEO-optimize your company, thank you!
