Camera Projection Matrix
  • Yingliang
    • Dec 2015
    Hello, I have three questions.
    1. I'm trying to export camera locations but I don't know how.
    2. And I try to export camera projection matrix, I get a .ppm file in which there is a 4 * 4 matrix, I support the projection matrix is 3*4, why is 4 * 4 in the ppm file?
    3. I also export the external paras, and I get six numbers for each image, does these six numbers represent for 3 * 1 rotation vector
    and 3 * 1 translation vector?
    Thank you very much!
    • 1350
    1. what do you mean by locations? If you're referring to the X,Y,Z position (the same one you see when right clicking a camera and selecting properties) you can do so by exporting their external parameters (or if you meant when exporting a mesh, you can do so by using the fbx file format)
    2. The ppm file is composed by two parts:
    the first part is a 3x4 matrix (ppm)
    the second part (the last line) file is the camera calibration radial distortion (5 values, it's not a 4x4 matrix)
    ppm is composed as A * rt , where rt is composed as [R T] and R is 3x3 rotation matrix and T is a 3x1 displacement vector
    (also remember that you can export matrices for opengl in the same export dialog)
    3. externals are exported as ImageName x y z a1 a2 a3 , so: image name, x y z position and first axis of rotation X, second axis of Rotation y, third axis of rotation Z
    Andrea
    • Yingliang
      • Dec 2015
      Thank you very much, Andrea! You really help me a lot.
