Does retopology increase the shape accuracy?
  • Victor Ramamoorthy
    • Jan 2019
    • 64
    If I start with a dense cloud, create a mesh and use retopology to finely divide the mesh, does it increase the shape accuracy or just redivide the old mesh? Thanks.
    • Jan 2019
    • 64
    To make my point clear, does retopology use dense cloud that was the starting point and rebuilds the mesh with photometric optimizations?
    • CG-Guy
      • Apr 2018
      • 151
      Most people who sell models prefer a clean mesh of quads.
      They call most scan art triangle soup. I use zbrush remesh tool which has a slider to reduce polygons because I make real time art not a piece that requires rendering for minutes or longer each frame
      If your art piece will animate topology and clean quads is important
      To answer your original question I think you will lose some sharp details using a retopology tool
        • 688
        I'm fairly certain re-topology doesn't utilize photo-metric optimizations.
          • 1366
          Hi Victor,
          I confirm that the retopology is only a post processing filter. It will most likely result in loss of details. However, remember you can apply the retopology filter also on a triangle selection and not necessarily to the whole mesh!
            • Jan 2019
            • 64
            Thanks for the clarifications Andrea and CG-guy.
