Bug in image masking?
  • jumpjack
    • Aug 2017
    I set a mask for my images, and I think it's working because reconstruction process is faster; but when texture is applied to final mesh, also the parts of the image which should be discarded are instead applied to the mesh, with very bad results.
    • 1350
    Hi jumpjack,
    is this on the same dataset of your other thread? If so, can you please double check the link? thanks!
