Exporting from 3DF Zephyr to Zbrush OBJ looses detail ... why
  • 3d.alliance
    • Feb 2019
    It seems the OBJ exporter from 3DF Zephyr is decimating the mesh to a blocky version ... I'm using the free version. The mesh imported into Zbrush is totally unusable.
    • 1350
    Hi 3d.alliance,
    if your photos have embedded GPS data (e.g. if used a cellphone with GPS on) zephyr will automatically use double precision (as georeferenced data need to be like that for GIS software). Zbrush most likely does not support double precision yet, so when exporting from zephyr make sure to check "local coordinate system"
    cheers!
    • 3d.alliance
      • Feb 2019
      Andrea - Yes that did the trick ... thanks!
