Combine imported mesh and dense point cloud to create new mesh
  • iam_msy
    • Jul 2018
    • 15
    I would like to know if it is possible to merge an imported laser scan point cloud as .ply and the 3d zephyr dense point cloud and create a mesh?
    Thanks.
    Hi msy,
    https://www.youtube.com/watch?v=oT0CK2Vcu_E - This should point you in the right direction! It's totally possible to merge third party scan data and photogrammetry scans within Zephyr (Pro/Aerial - not Free/Lite)
    Hope that video helps
    • iam_msy
      • Jul 2018
      • 15
      Hi cam3d,
      So after I make the unstructured file, structured, it is also taking the point clouds from the dense point cloud? I thought I was only taking the colours from it.
      Thanks.
        Once an object becomes unstructured, it means that it is "linked" to the camera information. This means that once a dense cloud becomes structured, it can be used like any other structured dense cloud regardless of their origin.
        In your case, I assume you'll have
        - dense point cloud 1 generated by zephyr using images only
        - dense point cloud 2 imported by laser scan
        It is up to you to know what you want to do - if you'd like you can merge the two togheter (select them (notice how selected objects are highlighted) -> right click -> merge ) or you can create two separate meshes.
