Lite 4.350 does not save filtered, densified, object but only the original
  • Victor Ramamoorthy
    • Jan 2019
    • 64
    I am using Lite 4.350 and it does not save the object after laplace filtering and densification in the .obj format. It always save only the original before filtering and densification. No matter how I do filtering or densification, only the original object is saved. The processed ones are left out.
    Hi Victor, with "does not save" do you mean "export" ? If so, make sure to select the correct object in the export window.
