problem generate object
  • mosskis
    • Apr 2019
    Hello, I am new with the 3DF Zephyr Free program and I have a problem, I have got many pictures of an object (spirit breaker head) but I can not get the program to build it completely. Most of the time it does not exceed the first 15 photos.
    I have tried many configurations, masquerade included and I do not get the whole object.
    I would appreciate any help.
    Sorry for my English (translated from Spanish with Google translator)
    Here you have the photos of the object:
    and a photo with finish process
    Thank you in advance
    Hi mosskis,
    you're having issues because you're dealing with very small images (600x600) and an untextured subject.
    While it is possible to reconstruct something from a synthetic view, the same principle apply - you will need a textured object for higher chances of success. In your case, masking did not help as the background is completely plain. I could quickly reconstruct 16/40 using Close Range / Fast, but regardless, you should aim at getting a better dataset.
    On a side note, you should probably use different software to extract the 3D model directly from computer memory. Anyways, you can accomplish what you're trying - try enabling textures or vertex colors for example and render your images at a higher resolution.
    • mosskis
      • Apr 2019
      thx Andrea, I extract photos from a video. The next is try extract from screenshot screen.
