Another problem with uploading to Sketchfab
  • davisba82
    • Jun 2019
    • 8
    I'm having a problem again with uploading to Sketchfab.
    I checked the API code again, so that's not the issue.
    I just started using 4.5 and I see that I don't have the option to limit the size of the export to Sketchfab.
    I usually set it to 50mb.
    I think this is the problem.
    Is this a bug?
    Thanks
    I just checked, and I confirm there's a bug in the automatic filesize limit, which is now always disabled. Apologies for the inconvenience, we'll fix it with the next minor update.
    Meanwhile, I suggest directly creating a decimated textured mesh with a low resolution to stay under the 50mb limit. 200000 vertices and 1x8196 texture size should work fine. You can change those settings from the texture wizard advanced menu, or you can directly select the new preset "low poly".
    • davisba82
      • Jun 2019
      • 8
      No problem.
      I'll try to give that workflow a shot.
      Thanks for quick reply, much appreciated!
      davisba82
        davisba82 - Ps sneaky bit of insider Sketchfab info if you decide to upload files manually:
        "...You can upload your textures via the 3D editor and it will not be counted in upload size"
        Alban - Co-founder & CEO of Sketchfab.
        Twitter May 2019
