Object rotation question
  • 3DEnthusiast
    • Jul 2019
    • 16
    Hi there,
    My question is this, Say I decide to shoot a sequence of 36 shots using a DSLR mounted on a tripod and aimed at a subject that sits on a turntable . This being done to capture a full 360 degree rotation of this subject. Let's further say that each of these subsequent images were captured after a 5 degree rotation of the turntable. If I then go back and shoot a further 18 images that capture the front half of this subject at 2.5 degrees rotation of the turntable per succeeding image and add them to the images that make up the dataset will I cause the front half of the 3d model thus generated to become distorted due to the fact that the image acquisition was not carried out using a uniform distance between each succeeding image?
    Haha! I was having math class flashbacks - if I understand your question correctly: NO your model won't become distorted as a result of non-uniform degree shifting. Uniformity is a good way to ensure you have an even coverage, but not having uniform degree shift metrics isn't going to be a direct cause of distortion.
    • 3DEnthusiast
      • Jul 2019
      • 16
      Yes, I see what you mean, those maths classes obviously left an imprint after all ! I did attempt to write out a reply earlier but the forum was undergoing some maintenance and I never got back to it. It had occurred to me that adding more images to the front half of a subject than the back half might cause some distortion so I thought it would be a good idea to check. Thanks for answering my question.
        No problem, here to help
