v4.5 exif data
  • mr_anderson
    • Aug 2019
    v4.5 exif data
    Importing pictures in v4.5 they do not show the exif data and also the result is much worse than in v4.3 (the same project, pictures) . Can this be fixed?
    There shouldn't be any problem with exif data in the new version. If you can send us one sample picture (or the entire dataset) at support@3dflow.net we can investigate your issue.
    Thanks,
    Roberto
    • mr_anderson
      • Aug 2019
      OK, thanks
        I checked the photo you sent to support, it all seems okay
        [14:45:56] Checking online calibration data...
        [14:45:57] Successfully received Online Calibration Data.
        [14:45:57] Applying Online Camera Calibration to FC1102 4.5 mm (3968x2976)
        if you want to send the full dataset i'd be happy to have a look
