Sketchfab API not being retained
  • sam3d
    • 98
    I have to keep entering my API number for Sketchfab everytime i upload; is there a way to save it in Zephyr?
    Thank you
    Hi Sam3D, the API key should be saved after the upload. Maybe it has been reset if you have made a new Zephyr installation? We'll investigate if there's an issue with the API key saving.
    • sam3d
      • 98
      Thanks Roberto. I'm sure I haven't had an issue in the past but have used the upload several times this week and had to add the key each time.
      I'm using v4.509 (Steam).
      Sam
        I was able to reproduce the issue. It was introduced since we changed the crypto algorithm for storing the API key locally. Thanks for reporting the problem, it will be fixed in the next minor update (probably next week)
