If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Hi Sam3D, the API key should be saved after the upload. Maybe it has been reset if you have made a new Zephyr installation? We'll investigate if there's an issue with the API key saving.
I was able to reproduce the issue. It was introduced since we changed the crypto algorithm for storing the API key locally. Thanks for reporting the problem, it will be fixed in the next minor update (probably next week)
