Export textured mesh greyed out
  • JonathanJObin
    • Nov 2019
    For some reason I'm not able to export a mesh on my project. I usually export and OBJ to maya with the texture but this time the option is greyed out and I have no idea why. Tried looking online and didn't find any explanation for it. Anyone able to help ?
    • 1358
    Hi Jonathan,
    it seems that you are using 3DF Zephyr Free, which allows you export only textured mesh. If the option is greyed out, you have probably generated a 3D model (untextured). Make sure to go again in the workflow menu and generate a textured mesh, before you can actually export it.
    Lite/Pro/Aerial allows you to also export the untextured mesh, if required.
    • JonathanJObin
      • Nov 2019
      Thanks Andrea,
      I'm using Lite 4.523 and the model is already textured. I'm gonna run it again in a new scene and see if the same problem happens.
        • 1358
        Hi Jonathan,
        are you sure you're not looking at the untextured model, but with color on the vertices? Can you take a screenshot so it's easier to help you? thanks
        • JonathanJObin
          • Nov 2019
          Yes sure it was textured. I ran Textured mesh Generation again and changed the preset from Default Single Texture to High Detail and now I'm able to export it.
          I usually only do a single texture because that's all I need but for some reason it didn't work in this case.
          Thanks for your help !
