Textured Mesh exporting Problem
  • Nedo
    3Dflow Cup 2018 winner
    • Nov 2016
    • 71
    Hi, i have a problem exporting a textured Mesh,
    when exporting to OBJ, there is no Texture file, just the OBJ and the MTL file.
    When trying to export in FBX, there is nothing exported, not even the model,
    and PDF3D and PLY export dont work.
    i tryed this with the black friday sale 3DFZ version.
    Hmm maybe i doing something wrong?
    Greets Nedo
    Hi Nedo,
    that's odd as the export should work fine. There's no differences between the Black Friday version and the other Pro / Aerial versions. I suspect some issues with the permissions or the path encoding.
    Could you please try to:
    - Export in a simple folder without any special char (something like c:\test\test.obj). Please make sure to have the write permission on that folder.
    - Restore the software default settings ( tools-]options-]Restore Factory Default Settings)
    Also, have you tried different datasets or the problem is just with one reconstruction?
    Roberto
    • Nedo
      • Nov 2016
      • 71
      Hello Roberto,
      sorry fo my late response (Final Christmas countdown this Weekend i will try
      everthing what you said, so far i only tried one Textured Mesh to export,
      interestingly i can't setup what kind of Texture format, it allways tries in .PNG
      I loaded the file into my 3DFZ Steam Lite edition and its the same problem.
      Nedo
