prorender | online Renderfarm for 3DF Zephyr
  • prorender
    • Dec 2016
  • Modeler17
    • Dec 2016
    • 27
    • Modeler17
      Modeler17 commented
      Editing a comment
      Hi Giacomo,
      Thank you for all of these answers to my questions.
      Regarding the question you wanted more information on:
      What I am trying to confirm is, once I scale the model, whether there is a quick way to disable/re-enable scaling.
      I assume scaling would be disabled if I delete all control distances and control points. But I want to know if control distances and control points persist any where without exporting them before deleting them.
      Thank you again.
    • Giacomo
      Giacomo commented
      Editing a comment
      Hi Modeler17
      thank you for your explanation.
      There is not a specific button to disable and re-enable scaling. Nevertheless you can select a previous action inside the History panel located on the left side of the main interface of Zephyr. You're allowed to do that as many times as you want.
      If you only delete control points /control distances your 3D model will keep the last scale value you set.
      Lastly, we have fixed the bug concerning volume calculation. Zephyr 3.1 will be released within the end of January and I would be glad to send you a trial key in order to test out its improvements. Feel free to contact me at giacomo.vianini@3dflow.net and I will keep you up to date.
      Best
      Giacomo
    • Modeler17
      Modeler17 commented
      Editing a comment
      Thank you, Giacomo.
      The history panel sounds like it will allow me to do what I need to do regarding effectively disabling and re-enabling scaling.
      I am glad to know about the upcoming fix for volume calculation save bug. The fix is something I will indeed want to test once 3.1 is available.
  • Giacomo
    • Nov 2014
    • 24
    Hi Modeler 17,
    I am going to reply you following your order:
    - Control points can be placed at any moment of 3D reconstrucion, even after the first phase of cameras orientation for instance;
    - At now it is not possible;
    - Yes, they can be created after creating a mesh;
    - Scale accuracy depends on user's precision while placing control points;
    - You will notice that the value of the control distance you exploited to scale the model is changed;
    - What do you mean by that question? Could you provide me with further details?
    - In that case, users are requested to perform scaling procedure again;
    - After you have placed your points in Zephyr, you can choose which points must be the constraints, namely the points you are confident (of their accuracy) the most, and which points will be taken into account as simple references. Let's think about an aerial survey where you have both coordinates taken by the GPS system on drone and some coordinates on the ground taken with a total station. The first group will be the points taken on ground with the total station since their accuracy is definitely higher than GPS coordinates taken by the GPS system on drone representing the second group.
    - Yes, it must be applied in order to reach a fine result;
    - They simply are two different methods to calculate and visualize meshes volume. As for the first one all holes are automatically filled and later shown with a red color;
    - We are checking the issue and I will keep you up to date as soon as it will be solved.
    Best
    Giacomo
    • Modeler17
      • Dec 2016
      • 27
      Hi Giacomo,
      Thank you again.
      • Giacomo
        • Nov 2014
        • 24
        Hi Modeler17
        Best
        Giacomo
